Yes but it won't be happy for long. Like any tree it is much better off in the ground, even if its a small section of earth the roots will penetrate far down.
If thats not possible, a sheltered, south facing space with a very, very large might do the job for a while. They are very happy climbing up walls
SOURCE: growing indoor avocado tree from seed
Make sure it doesn't stand in water, don't give it too much. Moist is OK, but it needs to all drain out. Also, don't let soil cover the top of the seed area. Mulch on top is OK, but not right over the base.
Testimonial: "Thank you for your answer. I will repot this into a pot that has better drainage and I will clear the covering from around the "trunk " where it goes into the dirt.I am confident that you have solved this problem for me because I had over watering problems in the past. I don't know why I did not match these two incidents together and solve the problem before it became this critical. I will let you know my results - in about two weeks - if I can ever find this site again. I am not too good with computers. When I was a child I drank too much water. I appreciate your answer. - Lester"
