Televison & Video Logo
James Allen Posted on Jul 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony kdl52w510 cycles off and ON 15 TO 20 SECONDS Flash code 10 good picture when on
shibu tv
Level 2:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 123 Answers
  • Posted on Dec 06, 2020
shibu tv
Expert
Level 2:
Greenhorn:
Cheetah:
Answers
123
Questions
0
Helped
31113
Points
165
Check the digital board or tunner board some sony tv's may not the board
2 Related Answers
Anonymous
  • 105 Answers
  • Posted on Oct 14, 2007
SOURCE: continueus green flashing light
i have seen weak lamps do this. this would also be the first thing the servicer would replace. worse case scenario you would have a spare lamp on hand...
dcgun007
Doug Crawford
  • 63 Answers
  • Posted on Jun 22, 2009
SOURCE: kdfwe42655 Sony Picture on approx 45 seconds;
http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=19 <try this and good luck! let me know if it helps...
Stops during cycle
some times the number of flashes and pauses will be an error code counting them could result in a solution also try turning off the breaker count to 5 turn on see if helps
3answers
Sony Cybershot DSC-W55 Flash Error Code
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Mar 24, 2008 • Cameras
Sony bravia turns on and off by itself then stand by light blinks 10 times
Google the model number of the set(not indicated here) for "error codes" or 10 blinks---Also look on the Sony site for this information--you can call them with the model number also.
2000 road king code 16 bike starts but won't stay running. not quite sure how to pull codes but it seems like I have a code 16(or I put it there during testing). crtank and cam sensors seem ok. resistance...
Code 16 indicates that the ECM has seen a battery voltage of less than 6.2 vdc or higher than 15.5 vdc. The most common cause of this is loose or dirty battery cables or shorted rectifier.
To access codes, turn the ignition switch on for about 3 seconds (one second after the fuel pump stops running) then turn the ignition switch off for three seconds. Repeat the above procedure. Then turn the ignition switch on again and about 8 seconds later the codes will start to flash through the check engine light.
If there are no codes present or there is a code and it does not appear again the code will clear its self in 50 start/run cycles. (Start/run cycle is defined as engine running for at least 30 seconds and off for at least 10 seconds.)
Flash Charging
The flash on these are normaly used in the auto mode. If there is very little power demand it may charge enough for the next picture in about 2 to 5 seconds. If the flash is used at full power, it can take a good 10 to 12 seconds.
When the camera battery starts to run down a little the flash charge cycle time will increase.
Jerry G.
1helpful
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
HV Sound no Picture
Sounds as though there is an intermitant, heat-related problem with the HV transformer. You can order this at a tv parts shop or from Sony (probably more expensive) the part number should be on the part or on a schematic. If not, the parts dealer can look it up from the model number.
Good luck! :)
1helpful
2answers
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Continueus green flashing light
3helpful
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
