ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
Plug in the Digitizer and make sure you hear four (4) beeps and 4 beeps only.
Any other tone would indicate a problem.
If you get four beeps,try to set the Superset code to S01 by using the stylus,select S,then 0 then 1 and you should hear four beeps again.
If this doesn't work the pen may have gone bad,have an open wire inside the cable.
It would have to be replaced. If you have another transducer,pen or cursor,try those.
The Food and Drug Administration requires the ozone that is given off by medical devices that are used indoors to be no more than 0.05 ppm.
If you have a manual, does it specify the amount of ozone given off?
I'd be interested in the figure.
