The TV was working fine and suddenly it went off and doesn't come up again after several attempts.
I checked for loose connections etc and everything seems fine.
The green light doesn't come either. I suspect power surge. Can some expert advice me on how to fix this?
Thanks!!!
It can be as simple as a blown fuse in the main power supply module, if you get not indicator light at all, then it will be the power supply has gone out, if you do get some indicator light, the 5v standby power supply is still functioning but not the main section of the power supply module. The filter capacitors look good, no bulging tops?
