SOURCE: Power port/ cigarette lighter keeps blowing fuses
the cig lighter might be shorting out and cauding the other problem. sell the car and buy a toyota.
SOURCE: my fuse blows everytime i plug in my sirius radio
is that the only device that is blowing a fuse? if it is the only thing blowing your fuse you may need to replace the charger. check the fuse to make sure it is the correct size ( usually 10 amp). check the power adapter to make sure there are no loose connections or anything in the plug that doesn't belong there. unplug the radio from the adapter and plug the adapter in without the radio see if the fuse blows . if it blows replace the adapter. if it doesn't blow the fuse check the adapter to make sure it is the right one make sure the polarity is correct
SOURCE: No power to radio or cigarette lighter adapter
to find the radio code for honda press 1 and 6 at the same time and while holding the 2 buttons down press the power button on it will show the code in 2 parts or call honda customer service and the have a line just for navigation and radio codes but u need the vin # and the serial # off the radio which is sometimes in the glove compartment or on a sticker on door jam
SOURCE: 2005 vibe radio and cig port stoped working
On this website (link below) you find fuse box diagram and description for Pontiac Vibe (2005 - 2008)
Pontiac Vibe 2005 2008 fuse box diagram Auto Genius
