SOURCE: POWER BUTTON BROKE, CAN'T START
Did the power button come off or did it stop working. Broke has a lot of meanings.
to sort this problame you should take the notebook computer to repair shop this is a technations job and need to be fixed by a expert . Trevor
SOURCE: unhooked and moved my computer to another part of
Sounds as if your monitor is not receiving a signal from your video card. In all likelihood, the video card came unseated during the move. Open the case and re-seat the video card, that should do the trick.
Write back if that does not solve the problem.
-Jon
SOURCE: I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular
extension cord. Power cable must plug directly into a surge protector
that is not daisy-chained to another power strip, surge protector, or
normal (household) extension cord. Surge protector must be directly
plugged into wall socket.
If none of the above solve the problem, open up the case and ensure
that all power connections are secure. Also check ALL other components'
connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Hi Gail Sanderson, I want to help you with your question, but I need more information from you.
Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
Hinduja Global Solutions is one of India's largest conglomerate businesses, employing thousands of people. They've experienced significant growth over the years, and as a result, they've increased their workforce significantly. HGS salary slip This leads to the implementation of an automated Human Resource Management System to ensure that all of their employees' needs and requirements are met directly through the platform.
Gail remove huge battery and test again
on Ac POWER PACK ONLY.
BATTERIES, DO NOT LAST 8 YEARS.
STEP 2 PUSH POWER FOR 10 SECONDS BUTTON AND RELEASE.
