SOURCE: Video Input
Are you sure that the source is generating a video signal? It is extremely rare for both front and rear Video Input sockets to fail simultaneoisly. from your description, i would suspect the cable connecting the Viseo out of your DVD player / Video Game than the Video Input ports of the TV. If you have another cable, just try again with that. Or, try using the Red to red cable into the Yellow port, using one end at the DVD player and the other at the TV Video Input. If there is image, then it is confirmed that the cable is faulty, and you can get a replacement cable for a few bucks at any Video store.
SOURCE: Bad AV Multiout on a Japanese PS3
Copied from another forum: "On the PS3 from Standby (red light on) depress the power button till you hear two beeps. That will reset the resolution and you should get a picture." MANY THANKS to the original poster!
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
SOURCE: WHAT does the USB port do on this satelitte receiver???
I think it's an input for playing AVI files using your flash drive. Why not give it a try
