Not enough water flow from pump to rotate the top arm. Dishes do not get clean and soap is not all used. I've removed the filter screen & arms to clean them but they were not dirty. The pump works but not well enough. What parts are most likely to fail in the pump assembly? I found the diagram on Sears website. I see there are several o-rings and a check ball (among other things) are any of these parts known to be problems? Which ones? I would like to order up the equivalent of a "rebuild kit" and fix the pump in one shot. Thanks
SOURCE: dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
SOURCE: Whirlpool Quiet GU2300XTLS2
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
SOURCE: DIRTY DISHES ,HAZY GLASSES.ALL SOAP NOT GONE
Sounds like the heater is not working, could be bad heating element, bad door switch, or bad heater relay on the main control board. Check for continuity on the heater element to rule out a burned out element. Do the same for the door switch, if all checks out good then replace control board with heater relay.
SOURCE: Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
SOURCE: Soap is left in dispenser, not enough water? dishes are still dirty
www.dishwasherfilter.com has a product out that will solve this immediately. check it out.
