Question about Emerson EWC20D3 20 in. TV/DVD Combo
V chip on and remote is gone
Is the v chip something you can removing by taking the TV back off?
  • 40 Answers
No. you are a child that wants to watch bad shows huh? well you are on the internet so do it here.
by the way, the "v chip" is just a basic programming in the computer so you cant actually take a chip out.
Posted on Sep 08, 2009
SOURCE:
Do i unlock the front panel lock on a RCA 27V55OT
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jul 09, 2012 | RCA 20F511T TV
Remote control sometimes is working, most of the time is not working, so I have to turn it on and off manually
Tries check the tv remote battery compartment for moisture and rust on the remote battery like + - connections inside of the battery compartment?Yes?Take somethings sharp or a knife scrap all the rust out.Take a rag spray some WD40 and clean the + - battery compartment connections.Change another set of a new battery.If after this the tv remote still have the same problems,than the remote itself rubbers inner layer of the rubbers knobs probally warn out and not anymore make correctly contact to the tv remote PCB board anymore or the CPU chip itself it is slowly dying and shorting out of the tv remote CPU,remote devices are heavy dependent on it CPU chips.Or try website like Remotes.com to buy the tv original remote or very closed clone compatible one.
Sep 05, 2011 | Olevia LT32HVE 32 in. LCD Television
How do i get my remote to work for my tv?
This is the tv original tv remote wright?Yes.Tries to take the tv remote aparts,if u can?Yes.Tries take some Q-tips soak with some rubbing alchahols and clean the tv remote PCB board and check the back of the rubbers soles nobs insulater between them,make sure they are not worn out.Take a piece of paper towel soak it with some WD40 and clean those batteries connections like - + to clean for moisture and some rusts.Wait like about 20 mins for the tv remote to dries up and put it back to gether again and replace it with new set of batteries.By doing these steps,the tv remote,will have a great chances it to work again.If u still get the same result after this,most like the tv remote main CPU IC chip is dead.Try website like Remotes.com to buy the tv original remote for the replacement.
Jul 11, 2011 | Apex Digital AT2702 27" TV
Its a rca tv model # 20v500t serial # f075e5e61 i accidently set the fra lock or something like that in the menu screen and cant turn the tv back on and dont have the remote
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  4. Hold down EJECT button on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jan 09, 2011 | RCA Televison & Video
Remote does not work
Remotes devices are heavily depened on it CPU chip,might the CPU chip is shorted and dead the remote is garbage.Tries take the remote aparts,take some Q tips dipping in some rubbing alchahol clean the PCB board and inner rubber layers,wait like about 20 mins. than putting it back together again put in brand new batteries,might get the remote to work again.Not try website like Remotes.com to buy an original or very close to the original remote.
Jan 06, 2011 | Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
Cannot turn tv on or off remotely. Tv works fine after turning on manually.
Take the remote control aparts,take some Q tips dips it in with some rubbing alchahol.Clean the remote control PCB board,putting it back together again,wait like 20 mins.Put in new batteries.The remote now should work again.If not it garbage,because it CPU chip is dead.Try website like Remotes.com to buy an exact remote to ur original remote.
Nov 18, 2010 | Quasar VV2007 20 in. Combo
The menu button, tools button and others do not work. Did I do something to lock these buttons? Power, volume, channel etc. operate properly. Less than six months old.
The remote is having problems with it circuit board or it CPU chip is failing.Take the remote aparts,take some Q tips dip it in some rubbing alchahol clean the circuit board and those - + battery circuit connections terminals.Wait like about 20 mins,than put the remote back together again.Now,all the contacts points ben cleans out.The remote should work again,not than the remote CPU is failing,sorry now the remote is garbage.Try website like Remotes.com to buy an exact remote or very close to the orignal remote.
Nov 08, 2010 | Samsung TV Remote Control
TV has no picture or sound. Was working fine then suddenly went black. Slight smell or something burning and just a clicking sound inside TV now. Any thoughts?
if it is 46F500 UNPLUG SET and remove back cover--on far right side as you look from the back you should see either two smaller or one very large heat sink with fins--the set listed has either one or two STK-392-110 OR STK-392-150 CONVERGENCE CHIPS.
Near them you will see about 12 resistors--look to see if any are burnt or slightly discolored in the middle---you have to look close at them--they can all be checked like checking a fuse--no reading and one is gone----
Point here is if any are bad or smoked--one of the convergence chips got them----the only other way to prove or disprove this is to get at the chips and un-solder all 18 pins on each chip--if set turns on--one is bad and BOTH NEED to be replaced along with any bad resistors--if you smelled something--something toasted--- these resistors are FLAMEPROOF or metal oxide--they will not catch on fire, just pop and go instantly.
Let me know what you find and I will help you--I am here to help people---If this helps you rate this solution as I do this here for free.
SD TECH
Nov 02, 2009 | Hitachi 46F500 46" Rear Projection...
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Parental and v-chip on and my remote is gone
Sooner or later you'll get to a point when not having a remote will get to be too annoying, so better get one now and take care of this problem. Also Emerson advice users not to use universals. Theres a way that might help you reset the system, i'm not sure it will reset the V-chip as well, but no harm trying. unplug the unit from the power line, and wait a good while before plugging it back. this resets some settings for sure, but it might be that the V-chip stores its settings differently. Then also check to see if there's any batteries supplying a small current for other settings memory, scour the face of the unit for a battery compartment and if you find one remove it for a while. Otherwise, you could try removing the V-chip. But i won't advice you to do that, opening tv's is kind of dangerous, and go find it in there... lol anyway, if you do manage to cancel it you wont be able to turn it back on, so unless you're content to keep the set in your bedroom locked, or let your kids have some fun, i suggest you go through the trouble of getting the remote. Maybe tell your kids that if they find the remote you'll go easy on them, let them watch some porn once in a while, you probably wont have to wait more then an hour before its in your hand, and find your lost golf clubs on the way... ;] good luck!
Jan 29, 2006 | Emerson EWC20D3 20 in. TV/DVD Combo
Emerson EWC20D3 20 in. TV/DVD Combo Logo
53 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
