RCA M4208  MP3 Player Logo
Posted on Sep 08, 2009
Unfreeze a RCA M4208GR-B! HELP PLEASE!
I have a RCA M4208GR-B it works just fine, but for some reason yesterday i turned it off and it hasn't turned back on. I've plugged it into the computer multiple times but my computer won't read it, and it won't turn it on. I've charged it, but that still hasn't worked. It's done this before and i plugged it into the computer and it worked, but now it's not working. I'm getting really frustrated! HELP PLEASE :)
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Oct 29, 2009
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
6901
Points
40
Try this:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2200
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
My RCA M4208GR-B 8gb mp3 player is stuck on initializing mode. I've tried everything i can think of. I was wondering how to get out of this mode and how it became stuck in this mode?
hey just turn off then back on if it still dont work plug it into the computer if still then call technical support have a great day
2answers
How do i dowload music to my opal M4208GR
Manual for RCA Opal M4208GR:
http://www.voxxsupport.com/images/manuals/M4208GR/media/M4208GR_DOC_OM.pdf
This player has default setup MSC mode, seeing the player as a flash drive also called a removable disk.
MSC = Mass Storage Class
When seeing the player as a removable disk in Windows Explorer:
Drag and drop the song, with mp3 or wma format, into the Music folder on the player.
Note: some wma files may have DRM = Digital Rights Management. These files might be copied or transferred onto the player but cannot be started for playback.
Important: in MSC mode always safely remove hardware, the players' removable disk, at the bottom right corner of the task bar.
Transfers to the player can also be done with software like Windows Media Player 11, RCA easyRip or other software from music stores.
This can be done in MTP mode. MTP = Media Transfer Protocol.
How to switch to MTP mode, seeing the player as Media device:
In the players Menu go to Settings. Go to Protocol. Select MTP mode / switch from MSC mode to MTP mode.
I need the volume louder!
try another set of headphones, well, not on the player, if its on the max then its maxed out. but basically if you connect it to speaker you can turn the speakers volume up even more.
might be bad headfones?
RCA Mp3 M4208GR-B is entirely unresponsive
This Mp3 player is ridiculous! My husband and I each have one (purchased Dec 08) and by Aug 09 his froze never to turn on again. I thought maybe he got a lemon because mine was still just fine. As of Dec 09 mine is unresponsive as well. Pretty junky piece of equipment if you ask me. Sure it was only $50 some odd bucks at Walmart, but I would expect it to last much longer than a year - especially because I had barely even used mine. Ridiculous. My best suggestion... buy a different brand. Junky ole RCA needs to retire.
1helpful
How to unfreeze mp3 player
i held in the power button for 5minutes,it shut off,then turned it back on.but now i have another problem,now it wont play my music.i cant get the plan so if u could just tell me what u think or know what to do i would really appreciate it.
Need to reinstall data on RCA Opal M4208GR-B
I did the same thing and reformatted mine too! If you go to www.rcaaudiovideo.com and put in your model number M4208GR and click on the update for the firmware update again then it will put everything back on the MP3 player. I know it sounds nuts but it worked for me and it wont do anymore harm then you have already done ;) Give it a try. Hope it works for you like it did me!
Easy Rip Software
Plug your RCA M4208GR-B MP3 player into your computer with the USB cord. After the computer recognizes it.
STEP 1 click start
STEP 2 click MY COMPUTER
STEP 3 Right click the associated drive letter (i.e. OPAL) to show the option menu.
STEP 4 click "install RCA easy rip"
9helpful
NO SOUND on Reason 3.0!!
click on file, preferences, make sure your sound card is enabled as output
4helpful
3answers
MP3 player won't turn on
mine usually turns on the next day
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
