Garden Logo
Charles Cherry Posted on Jul 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
20hp briggs an stratton riding mower want turn over but a half of a turn even with a jump
CJ Rock
Level 3:
  • Briggs Master 4,429 Answers
  • Posted on Jul 23, 2019
CJ Rock
Briggs Master
Level 3:
Answers
4429
Questions
0
Helped
1645112
Points
15024
Check oil level, if ok remove spark plug and crank engine. If it spins then likely "starter stall" due to valve lash out of tolerance. BS OHV engines require periodic adjustment of the valves.
If oil level is excessively high then likely engine has hydro-locked... the cylinder(s) are full of oil/fuel due to a stuck carburetor float.
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on May 12, 2009
SOURCE: gas comes out of spark plug hole
You have a Float problem you also make have gas in oil.
Geoff
  • 562 Answers
  • Posted on May 29, 2009
SOURCE: engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
Anonymous
  • 583 Answers
  • Posted on Oct 25, 2009
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Anonymous
  • 10 Answers
  • Posted on Apr 12, 2010
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
Anonymous
  • 2777 Answers
  • Posted on Oct 12, 2010
SOURCE: i need an owners manual for a brute riding lawn
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.doitbestparts.com/MANUALS/BRUTE/7800583.PDF
My simplicity riding lawn mower was submerged for about a half hour and will not start. what should I do?
change the sump oil , remove the plug and dry off, turn motor over with out the plug to empty water from the cylinder
remove fuel tank and empty water out , remove carby and empty water out
check all switches for water immersion
Wont go when warm
If you mean it won't start after the mower gets hot, that is usually a fire or coil issue, maybe even coil adjustment. You have to check for fire and adequate fuel as soon as it happens.
Why does my B&S engine runs wide open even with throttle off 20 HP
Check the cable connection down near the engine, it should be attached to the throttle lever, it is not uncommon for the screws that clamp the cable to come loose
Why is my 20hp B n G Keep flooding?
check that the float valve is closing fully may have dirt under seat.
Why won'y my 20hp Craftsman Yard Machine riding mower start?
when changing the belt you might have knocked off a wire to a safety switch
1helpful
20hp Briggs head torque specs
The following site details te Torque Specs for the 20hp Briggs.http://www.ehow.com/info_7929485_briggs-hp-twin-torque-specifications.html
1helpful
I have a scotts/john deere s2046 riding mower (man date 12/98) --hydrostatic trans making a groaning noise--want to fix it before it fails--is there a rebuild kit of some kind?
I would try and fill the case with 50 weight oil It might be low. The hose should come to the right side of the pully door on the middle of the tractor between your legs.
Terry
Top Briggs Garden Experts
Renee Knafel-Bullock
Kardoc
Stan Ford
Are you a Briggs Garden Expert? Answer questions, earn points and help others
