I got this free Pdf manual from reliable-store. com for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
The Aquatronics MS1550G is a marine stereo, not an antenna. If you are looking to mount an antenna to your boat, you will need to find a suitable location for the antenna mount and then run the coaxial cable to the location where you plan to install your marine radio.
Typically, the coaxial cable will run from the antenna to a hole or grommet in the boat's hull or deck and then be connected to the back of the marine radio. The specific location and process for running the cable will depend on the type of antenna and the layout of your boat.
If you are unsure of the best way to install your antenna, it is recommended that you consult with a professional marine electronics installer or refer to the installation manual for your specific antenna and radio
The light fuse on a 1995 Lowe boat with a 30 hp Evinrude outboard motor may be located in different places depending on the boat's wiring and electrical system. However, the most common location for the light fuse is in the boat's fuse panel or in-line with the light wiring near the switch. You can refer to the boat owner's manual or wiring diagram for specific details on the location of the light fuse. If you don't have access to the manual, you may need to inspect the boat's wiring system or consult a marine electrician to help locate the fuse.
do you have it hard wired to pos and neg or does it have the 3 prong plug in switch ..if 3 prong its for a 24/36 volt motor wont work on 12 volt less you have the 12 volt plug
Locks for this application will be available from a ships chandler. ( shop dealing with everything for the boats). Use only brass or stainless steer of marine grade quality to prevent rust.
Motion sensors are likely installed.Someone stepping on the boat may not trip it but putting the boat in motion might. Locate the sensors and disable them, then party on.
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor. This is only a solution for 3 battery system. For 4 battery system, connect 4 to 3 pos to pos and neg to neg. [email protected]
