Music from Micro SD card will not show up on "My Music"
I downloaded music from pc to micro SD card. It shows up on SD card and will play on PC. But, when I insert SC card into Blitz phone and go to "My Music", there's nothing there.
hi what you will need to do is either use a USB cable from your pc to your cell phone, the memory stick (micro sd) will show as a removable device then just copy and past the mp3 files that you want to copy, the other way is to buy a sandisc micro card adapter, this looks just like a normal SD card, but at the top of it there is a slot that you put the micro SD card in then put it in a card reader as normal, then transfer the music over to that disc, when done just pull your micro sd card from the adapter and insert it into your cell phone as normal and away you go...hope this helps
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
I speant Hours swearing at my phone because it would not read my music
files, Tried the card on many different phones which would take Micro SD
and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro
sd card in that and then putting your music files into the "sounds"
folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds
folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents,
Sounds, others and Videos on your Micro SD card. Format the card by
going My computer, Right click the Card reader (with you Micro sd card
inserted) and click format. Takes a few seconds. Insert the card into
the phone, the phone will auto put the folders on the card. Then go to
step 1 (above) and start again.
You must Have All Files In the my_music directory with NO sub directories. And as said before YOU HAVE 32 Characters.Most of your Mp3s will have a tag on it that will tell you (the phone) all the info you will ever need to know about a song.Some day lyrics.
The only way the music can be played on a cell phone is if it is in mp3 format. you also have to list the songs individually (they cannot be separated into folders). to listen to the music you should have some sort of music player on the phone that will play the songs.
If your music files are in a folder you cannot add them to play list, but if you have all your songs singly you can add them to your playlist, I had the same problem tonight with this phone, we added them individually no problem, this has worked but is a lenthly prosses, so far so good, not had a play about with them other than this, still to get them back as an album not yet done, Jackie
Any problems ring virgin, they were very helpful, SGH-J600 User guide not explained very well
