SOURCE: Maytag Performa pav2300 spins slow does not agitate
Are you missing any sox? you might have a sock (or other garment) wedged between the inner and outer tub.
SOURCE: MAYTAG LEGACY MODEL # SAV205DAWW
I've got the same problem. The diagram is a bit deceiving because it appears to show the agitator/auger as one piece. However, the bolt only holds the agitator (lower portion) and then the auger slips in place over that. The fabric softener cup then snaps to the top of the auger.
Best I can tell is that the slotted 'ears' on top of the agitator are worn thus preventing a secure fit between the agitator and auger. I just finished putting some hard thumb pressure on each of the ears and bent them outward some. The auger fits much tighter now and I'm doing a test run of clothes. It is holding but I will probably have to replace what they describe as the agitator / auger assembly, costs $53.54. I don't see any other fix but would appreciate further input.
Thanks
SOURCE: How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
SOURCE: my washer wont agitate ?
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch
If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch
If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor
Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys
The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission
The transmission could have either of these problems:
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
