Question about Power Acoustik PTID-4003TV Car Video Player
Screensaver how do i use the screensaver on the power acoustik ptid-5300
  • val_g Mar 11, 2008
    why dosent the screen saver work on the ptid-5300
  • Anonymous Apr 15, 2008
    dont no how to use screen saver
He is right there is no screen saver! Just the one that came with it. I called to get it changed and they told me that already.
Posted on May 19, 2009
There is not a screen saver where you can download. When it states screen saver it's referring to the DVD logo that bounces around when a DVD is paused for a while. You can turn that on or off.
Posted on Jul 10, 2008
    Scholar:
  • 151 Answers
This might be related to your question, read through the answers.
http://www.fixya.com/support/t126992-bypass_parking_brake_switch_in_order
Posted on Dec 09, 2007
Eu preciso da part dpt tpa 230a, que e touch screen
Posted on Dec 05, 2008
SOURCE:
How do i power it on without it being hooked up in car
if you have a 12 volts ac/dc adapter you can hook the 3 wires Black for negative, Red and yellow for positive and the stereo will turn on.
Jul 22, 2011 | Power Acoustik PTID-5300 Car DVD Player
I HAVE A POWER ACOUSTIK PTID-8970NRBT MY PROBLEM MY SCREENSAVER
Here is what I received from Power Acoustik for screensaver and desktop saving from SD card. "You need to have the remote in hand. Insert a memory stick or SD card that has the images you want to use. When the image is displayed, press the pause button on the remote. Then touch the screen to bring up a set of icons on the bottom. If you do not see an icon with a hand, press the arrows that are in a circle until you do. Once you see the hand, press it one time. It will save the image onto the internal memory. You will find the image in the screen tab in settings, under all the stock images."
Mar 17, 2010 | Power Acoustik PADVD340TV In-Dash...
Bypass having to use the parking brake on power acoustik ptid7250
no, you can't, because watching a video while you drive is an insanely stupid thing to do.
Feb 03, 2010 | Power Acoustik PTID-7250N Car DVD Player
How do i save screensaver images to my power acoustik PTID-7002NR
You need to upload then via USB. You should have a cable that came with your unit
Nov 04, 2009 | Car Audio & Video
How do i set my ipod to my power acoustik ptid 5300 when i plug it in it just says close
If you bought the correct cable it should work automatically. There are no settings. However, my 5300 was flakey right out of the box and I had to send it in for repair. It works perfectly now.
Jun 06, 2009 | Power Acoustik PTID-4003TV Car Video...
Help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
Jan 24, 2009 | Power Acoustik PTID-5300 Car DVD Player
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Ipod cable
you can get it at best buy. ill do some lookin' cause i have a pioneer head unit and i just built that cable. i might be able to do the same for you.
Dec 21, 2007 | Power Acoustik PTID-4003TV Car Video...
Cannot see video
What i did was get a switch from walmart. they cost less than 2 bucks...Get one that has 3 slots..1 for power, 1 for acc, 1 for ground. Plug the brake cord the acc, and splice the power and ground cords to the other two. When your switch is off you can watch video while you drive, when its on it will cut the video off and display that message.....
If you want to do it the right way, then plug it into the emergency brake line or the parking brake line...hope i helped
Dec 09, 2007 | Power Acoustik PTID-4003TV Car Video...
Power Acoustik PTID-4003TV Car Video Player Logo
291 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
