We have to go through the motions of selecting language etc before we can get it off. This old lady does not have internet. All she wants is to watch TV. Any suggestions please.
SOURCE: Casio Exilim Z57 Date and Language set up
OK, here's the fix. This camera has internal flash memory that is used to store settings and can be used for limited picture storage. Its use for saving setting is essential, however. If this gets corrupted then the camera won't save settings. Whoever said to format the internal memory had the right idea.
After much experimentation here's how. Remove your SD memory from the camera and turn it on. This will force it to run on the internal memory only. Run through the time/date/location setup again. It will complain about the memory card. Ignore this and press menu. Under Setup, select format. Choose format memory card and do it. This will format the internal memory. Once it is done, turn the camera off and back on. You'll notice that the problem is gone and it has remembered your last setup.
BTW, my camera is a EX-Z75. Not sure there is a Z57 model.
SOURCE: Setup Menu Appears Each Time I Turn On TV
The software of the TV might have been corrupted somehow. A problem that may have come strait out of the factory.
Most of the New Sharp TVs have a software upgrade port. In your manual, it will describe on how to do it. Best to call the number on the software upgrade page and tell them what happening. That way, they can get you the right patch or software to fix the problem.
SOURCE: Ipod 4th gen nano is frozen on the language selection screen.
That could be one of two problems: Either the cord of the click wheel has been disconnected from its socket which will be an easy fix and you only have to pay labor, or you may just need a new click wheel which should still be cheap.
SOURCE: ipod is stuck on the language display screen
the select button is probably not working...you need to take it to service center to resolve the issue...
SOURCE: language menu popup on E19T6W monitor
That's a manufacturing issue in that model of monitor. You have to live with it.
