Question about Exercise & Fitness
Appears onTredex treadmill by Universal after a minute or two of use .LOOP appears on the screen
Unit immoblize
reset the machine follow this steps and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 05, 2013 | Life Fitness 95T Inspire Treadmill
Does anybody know what a bar that looks like its loading on the bottom of the screen ans nothing works means on my x7i?
Reset the machine with the small button to the side of the power button, and disconnect the machine power cord by 2 minute and toucht the small swithc with the eraser pencil make click.
Now try again. However if the problem persist try this:
    • 3
    • 4
    • 2
God bless you
Nov 29, 2013 | Nordic Track Incline Trainer X7i...
Image 15 treadmill troubleshooting
Reset the treadmills and fix it. God bless you
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Nov 13, 2013 | Cadence Exercise & Fitness
FF appears on the display and treadmill will not operate
please follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Nov 03, 2013 | Proform 695 LT Treadmill
When turn it on just beeping noise
reset the treadmill. follow this steps and fix it. God bless you
1.
    • 1
    • 3
    • 4
    • 2
Oct 23, 2013 | Reebok Exercise & Fitness
Fitstride t920 treadmill faults
Reset the machine follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
· 2
· 3
Oct 07, 2013 | Exercise & Fitness
Factory reset code
follow this instruction and reset. God bless you
need replacing, or move on to the next step.
  • 2
    treadmill.
  • 3
  • 4
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2Z4hlSTfH
    Jul 15, 2013 | Landice L7 LTD Executive Trainer Treadmill
    I have a vision T9500 treadmill. My husband was recalibrating and it got stuck in the highest position and is displaying E5 in the window. Any ideas how to get it down?
    hi,
    Try AUTO-CALIBRATION first. For that do the following.
    With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START.
    (The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen)
    If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module.
    OK
    Aug 27, 2011 | Dmm Vision Fitness T9500 Treadmill
    Reebok 8700es treadmill w/ Universal iPod dock & Ifit Fitness Journal. Display screen is unreadable. Light is on but unable to read the numbers on the screen Treadmill features: Custom workouts,...
    If the display is unreadable, the Display resolution is faulty
    Time to replace since thee are LCD, this fail.
    Call to the supply treadmill manufacturer. or
    Treadmill Treadmills Best Treadmill Treadmill Doctor
    Blessing
    cuadra2016@yandex.com
    cell+whatsAPP:+50588611441
    Nov 08, 2017 | Reebok 8700 ES Treadmill - Silver Service...
    Landice treadmill
    You may want to take off you head board and check all the connection. this is not hard to do. Also when you in there check you cable connection. can you do this?
    I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
    Jan 10, 2009 | Landice Pro Sport Trainer Treadmill
    Exercise & Fitness Logo
    Top Exercise & Fitness Experts
    Treadmill Repairs...
    Tom Chichester
    ray gallant
    ray gallant
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
