My Whirlpool Ultimate Care ll super capcity Imperial gas dryer will only work if I hold the Timer Knob, if I let go of it, it shuts off. And it will only work in the heat mode, not the air fluff or energy preferred mode.
The timer contacts are worn. Replace timer.
Testimonial: "I just want to say, thank you for your timely reply and expertise. I suspected the timer but was not sure, now to find the part. thanks"
It also would not hurt to try and blow out the timer assembly with compressed air...I was having trouble with mine and i had pulled out the timer. blew it out with compressed air, and re-installed and it worked again. If not then you will need to replace the timer like the other person stated.
