Question about Xerox 212 Laser Printer
Xerox 214 copier - U 4 code....what does it mean?
  • 239 Answers
A U-4 code mean the machine did not reach to temperature.
On this machine check to see if the side door is completely closed.
This door also has some to close with a circuit board on the side.
Check to see on the side door if the small flat metal springs are aligned and not bent, with the power cord disconnected. If these metal springs are out of place a short can occur. Be very careful in this area. If you are not sure what you are doing do not try to service this area of the machine.
One other thing, if the machine has been stored in a very cold place, brining the machine to a room temperature will take about 2 hours for the machine's circuit boards just to warm up.
Usually on this problem, it may be a combination of problems. It means a new fuser assembly, or main circuit board. Not easy to get to, it is in the middle of the machine. Everything has to be taken apart without breaking other components.
Be very extra careful if you are doing this work yourself. This is why you should place a service call for a Xerox service rep to do the repair.
Posted on Oct 17, 2009
SOURCE:
Shows error 214-315
Are u sure of the error code ?
Fault code 124-315 : ESS PWB Fail
Mar 02, 2016 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Errorcode016-214 at xerox wrkcenter pro128
1. Make sure the optional Hard Disk Drive has been installed
2. Power the machine off and on
May 05, 2011 | Xerox WorkCentre Pro 123 Copier
Copier is a 214 and shows U4 code
turn on power while holding down "0", press "stop/clear" and wait 30 seconds for optics to finish initializing, then enter "401" then "print", shut off machine, wait 10 seconds and turn back on. code should now be cleared.
Sep 06, 2009 | Xerox 212 Laser Printer
Copier is a 214 and shows U6 code
A U-6 means the memory on the main board failed.
If the machine is old, the battery on the board is old and not holding the values in the machine.
Replace the main board will correct the problem.
Since it is in the middle deep in the machine you might need to have Xerox repair it for you if they still provide service to this model.
Good luck.
Missing user's manual.
Google a business called " the parts drop". Call and ask for Britt, he most likely has one.
May 16, 2009 | Xerox 212 Laser Printer
Xerox 214 dc
It means the cartidge alignment is dis-balanced. So you need to fix it and may be re-fill cartidges also.
Dec 11, 2008 | Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON...
Xerox Copier 214
A U4 is a fuser overtemperature.
You can hold down the "0" while powering the machine on. That will enter the machine into diagnnostics.
Next enter code 401, and press start, See of that clears the problem.
If it does. Remove the fiser and clean the buildup off the thermistor.
If it doesnt you will most likely have to replace the fuser.
Jan 29, 2008 | Xerox WorkCentre 214 Laser Printer
Xerox 214
That is a fuser overheat message.
You can try this. Enter diagnostics. To do that turn the machine off, then press and hold down the ( 0 ) zero button while you turn the power on.
Once the machine comes on in diagnostics. Enter code 40 1and press start to see if it clear the fault.
That is enter 40 press start then 1 press start.
If that does not resolve the code you need to replace the fuser.
Dec 10, 2007 | Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON...
Xerox 212 Laser Printer Logo
611 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
