Question about Sony Televison & Video
Sony KP-53HS30 will not turn on & no sound. The power button on tv & remote does nothing. The only.ight is solid red stero light
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: Sony KP-53HS30
sent the info to your email address
Posted on Mar 31, 2008
  • 126 Answers
SOURCE: sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Posted on Dec 24, 2008
SpotBert
  • 231 Answers
SOURCE: connecting the laptop VGA output to my Sony-KP-53HS30
There are products such as VideoSecu PC to TV Presentation Converter. I haven't used them. I'm not sure you are going to get the resolution that you want. A DLP projector does a pretty good job. I know that is not what you are looking for.
Type "PC to TV Converter" in Google. They are about $40 to $60 bucks. Before you buy one, read the reviews.
Posted on Dec 27, 2008
SOURCE: Sony Wide Screen Projection TV KP-51WS520
I had the same problem. blinking 9 times, pausing, 9 times...... remote would not power the tv on. after five minutes of pressing the remote it finally would. after turning it off you would have the same problem. sometimes a half hour of pressing remote in every which what way. finally left the tv on for three days and would mute at nite to go to bed. didn't think that was the best way so turned it off and it never turned back on. checked all the forums and found out it was the g board. unfortunately, you cant buy the whole g board anymore. if you take the back panel off the tv, on the lower left corner is where the g-board is. there are 3 little things to unplug and two screws (phillips head) in the middle of the g board. its simple to figure how to take it out. go to the sony direct parts website. the part # is A1054157A for the g board. since they dont sell it anymore they have a phase 3 program where you send in your old g board and they repair it for 64.95. it'll cost about 8 bucks to ship it to them. better than the 400 bucks the tv guy wanted. address is sony customer satisfaction ctr. , materials door 27H, mount pleasant, PA 15666 there number is 866-748-8272. call first and they give you the step by step instructions what to do. after tax and shipping it came out to less than 80 dollars.even came with a warranty. got it back in a week, popped it in and just love turning the tv on. anyone can do it.
Posted on Feb 06, 2009
skotkolr
  • 558 Answers
SOURCE: red ight keeps blinking on tv
Although I think DS above is selling there are three caps in between the small heat sinks that pop and go bad, I have replaced these and the tv has been fine. if you like you can contact me about this repair.
Posted on Apr 03, 2009
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
light flashes six times.
Aug 15, 2012 | Sony KP-53HS30 53" Rear Projection...
Our Sony KP-53HS30 53" HD-Ready Rear Projection TV
According to the tech manual I looked at, it's a bad board - it just doesn't say which board. Sorry. Looks like it's making a trip to the shop.
Good luck.
Jul 06, 2011 | Sony KP-53HS30 53" Rear Projection...
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony kp-53hs30 projection tv
Good Day,
It sounds like your TV is experiencing a convergence problem. You should contact a Sony Authorized Service Center and have them come out to your home and give an estimate before they proceed with the repairs on your 2001, $1,900.00 TV.
Good Luck, big IRISH.
May 27, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony dead
3 blinks is over voltage you will have to cal a tech
Sony rear projection tv dead in the water
+B overvoltage protection either IC501 or IC5002 are defective they are both located on the G Board
May 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Status light blinking
your flyback is bad on the D board thats what makes the led blink 8 times replace the flyback and you should be fine. If you need a link on where to get the flyback and instructions on how to change it let me know and I will post a link
May 25, 2008 | Sony KP-53HS30 53" Rear Projection...
I have the same problem as faye95. My Kp-53HS30 tv clicks on and then turns back off and red light blinks on and off. Can anyone tell me what the problem is and where can I get a free service manual o
Free service manuals are hard to find and often they are complete. You can get the sony factory service manul at the following link for 15.99 and they will give free unlimited online tech support when you get the manual. They email the manual and info on getting the support instantly after purchase. heres a link if you would like.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Sony KP-53HS30 53" Rear Projection...
Video 1 stuck in the corner of tv.
press the display button on the remote sometimes the button on the sony tvs has a tv symbol with a asterisk in it thats the display button hope this helps...
cheers woodatoni.
Dec 04, 2007 | Sony KP-53HS30 53" Rear Projection...
No Power, standby light blinking, power cord in/out two quick clicks
sounds to me to be a shorted HOT transistor or short somewhere. the click sound is the switch mode power suppy powering up sensing a short and quickly shuts down. the hot transitor is mounted to a heatsink near your flyback. check for emitter to collector short. you can try replacing it if shorted and if lucky that all that was ..but if shorts again you looking at probably a bad flyback. good luck
Aug 17, 2007 | Sony KP-48S75 48" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
