Hi Betty, I send you the link to download the user manual of your ZS-PS50
I hope you can resolve your concern
Greetings Franco Dosil
Hola Betty, te envio el link para que descargues el manual de usuario de tu ZS-PS50
Espero que puedas resolver tu inquietud
Saludos Franco Dosil
https://www.appliancesonline.com.au/public/manuals/Sony-ZSPS50-Boombox-CD-Player-User-Manual.pdf
https://www.manualslib.com/manual/1333767/Sony-Zs-Ps50.html https://www.sony-latin.com/es/electronics/support/boomboxes-zs-series/zs-ps50/manuals
SOURCE: broken antenna
The Sony part number is: 175422611 and the part is available for $15.95 from tritronicsinc.com or any other Sony parts distributor.
Dan
SOURCE: I have a Sony" Personal Audio System" /boombox.
Hi, this is a pretty common problem with C.D. players, the laser has lost a bit of its intensity. This possibly can be fixed by adjusting a very small " semi-variable resistor " this should be located on the laser assembly or on the ribbon cable just before the laser. It may be a colored plastic dial with an arrow on the top, or a metal looking screw type looking adjustment ( probably has a bit of enamel to lock in place-this breaks free easily). It may even be labeled " bias ". Use a small phillips jewelers type screwdriver for the plastic kind and a slotted jewelers for the metal. move the adjuster in very small increments one way then or the other if need be. Make note of the original position in case you need to adjust different semi-variable resistors. also its even possible to have a dirty lens, use a jewelers loupe or equivalent to check. a very light touch with a Q-tip dipped in rubbing alcohol should do the trick. use opposite end to dry, be sure to not apply excessive pressure-the lenses suspension is extremely delicate. I hope this was useful-let me know if so or even if not so I may try again. Thanks for asking FixYa-good luck, Prodzilla
SOURCE: I have Sony ZS-D55 boombox.
Hello
All the Sony components are avialble with Sony Authorised Service center. You can contact them for the replacemant part. If you want to buy it from an other source try with "Alibaba"; "Ebay" "AB components" [Songapore] etc. They will have the exact component of your need, give them the model number and part which you want to muy from them. Can be bought by E-Payment. They will reach tghe compnent at your doorstep.
If you want any manual of your device, ie, user manaul or service manual; send your email address to me by FixYa comment box. I've both of them and will send a copy of it to you by return mail.OK.
SOURCE: Sony personal audio system boombox ZS-D55 Malfunction
The disc loading mechanism has the fault. Might be a loose or brokent loading belt. Check it.
SOURCE: I have a Sony S2 Sports ZS X1 Radio/CD Boombox that won't power on.
There is a fuse on the power supply rectifier board. Check it.
