Rear grill won't stay in slot. Manual mentions a plastic nut; none in the box. When front grill put on (lasko oscillating multi-purpose stand)fan stops spinning.
The rear grille is held in place by a really big plasic nut.
As it's self-assembly, it wouldn't be a bit surprised if the nut is in-place on the fan-body & you've missed the bit in the instructions, where you're supposed to remove the plastic nut, BEFORE you fit the rear grille in place.!
THEN the plastic nut goes in place & holds the rear grille in place, firmly against the fan-body.?
Unclip the outer grille.
Unscrew the nut which holds the fanblade in place (remembering that it's a reverse thread.!!!)
& then take off the rear grille.
The big plastic nut should then be visible.?
Unscrew it, put the rear grille in place & then screw the big plastic nut firmly in place.
Refit the fan blade & nut, clip the outer grille in place & you should be good to go.!
