Hi. Trying to program AKAI LCT2721AD with Tivo DirecTV Remote control. Codes given on DirecTV setup menu are not working (also tried Samsung codes).
Receiver is Series 2 R52180 (DVR R10).
Any direction would be lovely as other forums have turned up empty :(
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Fwiw, on a Charter/Motorola DVR, the remote code that worked with the Akai LCT2721AD is "11675". Not only controlled the TV but also the integrated DVD player. I saw in another forum that the same code works with DirecTV.
Here is the manual:
http://www.directtv-advisor.com/support-files/direct-tv-remote-manual.pdf
This is not the remote i am using...i am trying to program with black Tivo DirecTV remote.
learn mode
tivo code
