The staus panel has a probem and is not displaying any charactures - the status monitor (3) is stating "Panel Setting". How can I find out what the panel is saying?
that switches r made basically changing dvi to vga r vga dvi,if that switches r malfunctionig display goes to blank that means if u connect vga system will have dvi
loricaney, Do some research first. Go here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ I just read a comment that some guy wrote. He stated that he aquired 30 Vs17 non-working units from a high school, and that 25 of them had bad (swollen or leaky) filter capacitors. The other 5 had cracked lcd panels. maybe $6 in new capacitors will restore unit for you. Do some reading in my fixya profile and "budmrtn" and "buddymc" fixya profiles. let me know if you want to do a DIY repair after you do research and visit YOUTUBE for video clips of owners doing typical capacitor removal and installation. 12fixlouie
1. replace drum unit
2. after replacing reset the counter - press "3" and "9" button at the same time in the ready state, the reset menu will appear on the LCD, select "DRUM" and press "ok"
resetting without actual drum replacement might damage your printer.
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
rking3905, Please tell me if F1703 is BOTH BLACK and BLANK, or if it is just BLACK! If the screen is BLACK and you can see the WIN-desktop with aid of flashlight held 1" from the screen then the monitor's "switch-mode-power-supply" is in partial shutdown mode having detected a FAULT condition with the "cold-cathode-fluorescent-lamp" power supply called an INVERTER circuit (12vdc to 600-1200vac) to light-up the lamps hung on the rear of the LCD panel which produce WHITE light so you can see the image or text displayed on the LCD glass panel. In any case, you or a technician will need to evaluate the true state of your monitor. Also try to view some video clips on YOUTUBE that deal with "LCD monitor disassembly" and "LCD monitor repair". The longer (8-12min) clips are best. FYI goto www.ccl-la.com/badcaps, www.lcdparts.com, www.badcaps.net for more information on what may be the cause of your BLACK and or BLANK screen! If this was of some help, please rate this response on fixya.
12fixlouie
Hi , The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
Go into Brother printer control centre and bring up brother staus. Shows all the colour levels. Next lift printer cover up and remove carefully the cartridge that is showing empty. replace carefully making sure it is all the way in. On the printer panel push INK MANAGEMENT. scroll through until you find clean. make sure cover is back down and press clean of the particular cartrige you are having a prolem with. ei BLACK press clean black. On the Brother status monitor on your PC you should now see that the black is full
try swapping the computer power cable and don't connect the vga cable with the system. if you get a power on self test displayed it makes sure that the monitor is fine. if nothing is displayed you can take it for repairs or else call 1-800-624-9896 its Dell technical support number or log on to support.dell.com
