It is random. It sometimes will shut itself off every 30 seconds for a few minutes or turn itself on randomly
SOURCE: Random shut-off
The number one thing I have found with intermitent shutdown is the lamp door switch in the up position.
This series of models came back from the factory with the switch in the up position and it needs to be in the down position.
Take a flash light and look through the slots on the lower left side of the lamp door in the back of the set. If you can see the top of switch, then, thats whats causing your problem.
Take off the door, there is a tab that holds the switch down. Reseat the door and check the switch again with a flashlight. If it is down, then the problem is solved. If it is up, try again.
If you have anymore problems or questions, reply to this post and I will respond.
SOURCE: Permanent Connect and disconnect with K750i
I had the same issue with my LG Vx8700 phone. Turned out to be the phone and not the parrot. Am on my third replacement Vx8700 and it is working fine for now.
SOURCE: i have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
SOURCE: '97 Honda Accord- Horn honks spontaneously; honks
THE SWITCH IN THE STEERING WHEEL IS PROBABLY GOING BAD OR HAS A LOOSE CONNECTION THAT IS GROUNDING OUT AND COMPLETETING THE CIRCUIT AT RANDOM. I REALLY DONT KNOW HOW OR WHY SHUTTING IT OFF WOULD TEPORARILY FIX THE PROBLEM BUT WITH ELECTRICAL PROBLEMS ANYTHING IS POSSIBLE BELIEVE ME. ALSO TAKE A LOOK AT THE WIRING AND THE HORN ITSELF TO SEE IF EVERYTHING LOOKS OK THERE.
