SOURCE: Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before
resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
SOURCE: printer is flashing orange in equal increments.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Flashing Orange light will not stop printer will not print
THIS IS A CARTRIDGE OR PAPER JAM ERROR.CHECK FOR ANY PAPER STUCK IN THE PRINTER,ALSO TRY REPLACING INK CARTRIDGES
Hi Andrew , I want to help you with your question, but I need more information from you.
Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7/
