SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
SOURCE: why is my machine skipping stitches
this is caused by uneven winding of the bobbin, sometimes the spool of thread winds unevenly when it travels up and down the spool. the best solution i have found is to use small spools of thread when winding the bobbins
SOURCE: kenmore 1941 sewing machine irregular stitches
try rethreading the machine top & bobbin make sure to get ever thread guide
try chaning to needle, make sure the needle goes all the way into the needle holder-normally flat side goes to the back of the machine
check to make the thread is moving smoothly around the tension dial
if these suggestion don't help, then the machine probably could use a servicing
SOURCE: kenmore 100 stitch machine will not form stitches
it's probably time for the machine to be serviced
