RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
RCA Cable Box Codes: 000,027
RCA Universal Remote Control Programming Codes
Programming Your Universal Remote.
Special Notes:
RCA, GE and Proscan Brand Devices:
Many of these devices (TV's and VCR's) will not need to be programmed.
In the event that programming is required, the code search method is suggested.
The remote may already be set up to operate your brand of TV, VCR, or
Cable Box. It is pre-programmed with following codes:
For brands that
require programming, there are two ways to program: Using Code Lists or
Code Search. Use Code Search if the code lists are not available or if
the codes from the lists do not operate a device.
Programming a Device using Code Search:
Programming a device using the Code Lists:
To program the code for your RCU 800B (also known as the RCU403) universal remote control, follow these steps:
If you are unable to find the code for your device or are unable to program the remote using the steps above, you may need to try a different programming method. You can find additional programming instructions in the manual for your remote or by contacting the manufacturer.
