Question about Maytag 22.1 cu. ft. Bottom Freezer Refrigerator w / Factory Installed Ice Maker
Faucet Attachment Leaks
The faucet attachment leaks when connected to the faucet. The dishwasher is over 4 years old. I think I need to replace the faucet attachment? How do you do this? Do I need to replace the entire coupler assembly? How do you access the hose? Would this solve the problem of leaking. Thanks so much for your assistance. I have the same problem. First, replace the rubber o ring type thing found just inside the dishwasher nozzle end. Carefully remove it, making a mental note as how to put the new one in. Make sure you get the correct one for your washer. Smooth vaseline around it to help keep it from drying out sooner-- this will be an easy fix. If it still leaks, try replacing  the faucet adapter and save the receipt-you shouldn't pay more than $5 or $6. If that makes no difference, then take the adapter back and inspect your faucet as it may have worn out treads and the whole thing needs replacing. I have replaced my faucet with a much nicer pull-out sprayer that will require a trip to Lowes for the correct adapter that I was promised. I'm keeping my fingers crossed. By the way, faucets are NOT hard to replace. have done this but mine still leaks
  • Anonymous Dec 09, 2007
    Please disregard: ...have done this but mine still leaks...
    Also, this post is for my dishwasher but the maytag freeze somehow popped up :( There wasn't a way to edit this out!!
    Novelist:
  • 166 Answers
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
SOURCE:
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
A stripped garden hose attachment How do I fix a stripped Garden hose attachment?
If you have the correct size die you can rethread it. If not.
Turn off water remove old faucet and replace
turn on water and check for leaks.
Hope the helps Mike
Note: You may also take a razor knife
start at the top of the threads (near handle) and spin around and down to open the threads again. BE CAREFUL Then do this again with a small flathead to open them wider and slowly connect a known good hose end on and off several times
Jan 23, 2016 | Dehumidifiers
Leaking diverter valve
is it a kitchen faucet or a tub faucet? if it a kitchen faucet it will be a cartridge issue, if it is a tub faucet it could be as easy as a o-ring or a separate cartridge. in any case the cartridges are usually in the main part of the handle and you usually have to take apart the faucet. i know this may sound funny but make sure you turn off the water to the faucet, you would be surprised how many people try to fix this with water on.
Aug 30, 2012 | Kohler Plumbing
Moen two-handle kitchen faucet, 1990's model installed new a few years ago, is leaking underneath at the center where the spray hose would connect. I didn't use the hose, though. The nut was tight. It...
The nuts used for capping off the sprayer attachment will bottom out and not seal. Unless there is tape or thread compound on the nut, it can spray a tiny jet up under the faucet when the faucet is activated. If there is clearly water leaking from above that, then the o ring for the spigot may be failing and need replacing. If this is the case, it will only leak when the faucet is activated. There is always the possibility of a crack in the casting of the faucet body; hope not:)
Aug 22, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
Faucet solution for hooking up portable dishwasher
there is a generic adaptor that fits on your faucet; take the name, model# and, hose to a hardware store and, they can show you the right adaptor for your machine
Sep 15, 2009 | Dishwashers
I cannot get the attachment on my appt. size
The hose fitting goes onto an adapter that screws on to your faucet. You have to have the piece on your faucet for it to work. As best I can recall, once both pieces are in place, you pull down on the locking collar on the hose, put it on the faucet and relaese.
Best regards, --W/D-- please feel free to rate this solution..thanx!
Aug 01, 2009 | Kenmore Dishwashers
The connection from the dishwasher hose at the faucet leaks and sprays water. I tried changing the rubber seal in the hose, but that didn't help. any other suggestions?
Hello raymun30,
Welcome
You said,the connection from the dishwasher hose at the faucet leaks and sprays water. I tried changing the rubber seal in the hose, but that didn't help. any other suggestions?
What is the Make and model number of your portable dishwasher?
And how old is it?
If I have the number can look into the repair manual and at the diagrams and tell you what part you may need.
Find the complete model number. Waiting your response.
Huuum
That connector attachment can be replaced!!!!!!
Oct 20, 2008 | Dishwashers
The o rings need to be replaced and plumbers lube added on the interior of the connection point.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
May 15, 2007 | Kenmore 17259 Free-standing Dishwasher
Maytag 22.1 cu. ft. Bottom Freezer Refrigerator w / Factory Installed Ice Maker Logo
608 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
