New scooter, salesman says flashing light o.k. that it is fully charged . they didn't furnish charger manual
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
SOURCE: I have a 3yr old
Kay the status light flashing indicates a problem. Count the nunber of flashes and your manual should tell you what the error code means. Also check the freewheel lever and make sure it is drive position. Without knowing the number of flashes I can't tell you what the problem might be. Hope this helps
Testimonial: "freewheel lever! thank you very much"
SOURCE: my charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
SOURCE: My DMC-TZ3 battery charger green light is flashing, why ?.
According to the charging manual ( Panasonic LUMIX DMC TZ15 Operating Instructions Manual Charging Battery ) it could be caused by dirt. I've tried to clean my charger, now it works fine. No more blinking green light, just a constant green light.
