SOURCE: Shift 3 Projection Alarm clock remote cannot open
Once the batteries are installed in the remote the temp will appear in the LED screen. Now you are ready to link signals between the main unit and the remote. Simply remove one of the two triple A batteries from the main unit and then replace. You should then see what appears to be a flashing object shaped like a kite with a tail while the two units link up. Then you should see the temp reading at the remote appear in the LED readout at the main unit. By the way there is also a very small reset at the top of the switches on the back of the main unit that can be depressed with a SMALL pointed object like a scissor point or safety pin point.
SOURCE: Emerson cks3528 Dual alarm clock radio smartset
You can get the manual on the link below. Please alow time to load large file.
http://www.emersonradio.com/owners/SmartSet%20Series/CKS3528_110606.pdf
Good Luck and please rate 4 thumbs up for the free answer
Testimonial: "Thanks SO MUCH!!!! I've tried every button or set of buttons to set the "wrong" time zone for correct DST just to mess up Date too. Thank you SIR!"
SOURCE: Have "The Hammacher Schlemmer Projection
Please confirm if this is how you change the timezone.
1. Locate the "Mode" button on the front of your Hammacher Schlemmer projection clock.
2. Press the "Mode" button, and wait for the clock to show the day of the week in place of the seconds on the clock's display.
3. Locate the "+" button on the front of your Hammacher Schlemmer projection clock.
4. Press the "+" button to access the time zone-setting screen. Note that icons for the Pacific, Mountain, Central, and Eastern time zones will appear on the screen.
5. Press the "+" button repeatedly to highlight the desired time zone icon on the display screen of your Hammacher Schlemmer projection clock.
6. Press the clock's "Mode" button to return your projection clock to its regular timekeeping mode.
Also, try to see if you have a button to reset back everything to defaults then try again.
SOURCE: I have a blue hat toy co. time and space
We also purchased the same alarm clock and I accidentally figured out how to convert to 12 hour (AM/PM) format from 24 hour format. Once the time is set correctly, and you are out of the time set mode, you can press the UP key and it will toggle between the formats.
1. Hold down the "MODE/MIN" button for 3 seconds, the time will flash in the Time LCD.
2. Press and release the "SNOOZE" button to advance to the time zone selection.
3. In the indoor temperature/humidity section of the LCD the time zone will flash."
