2004 Pontiac Grand Prix V6-3.8L VIN 2
Power Steering Pump: Service and Repair
Power Steering Pump Replacement
NOTE: The content of this article / image reflects the changes called out by TSB: 05-02-32-004.
Removal Procedure
1. Remove the accessory drive belt.
2. Raise and support the vehicle. Refer to Vehicle Lifting.
3. Remove the tire and wheel assembly.
4. Disconnect the power steering pressure hose from the power steering pump.
5. Disconnect the power steering return hose from the power steering pump.
6. Disconnect the harness connector (4) from the power steering pump (1).
7. Remove the power steering mounting bolts from the power steering pump.
8. Remove the power steering pump from the engine.
9. Remove the power steering pump pulley from the power steering pump.
10. Remove the power steering pump reservoir from the power steering pump.
Installation Procedure
1. Install the power steering pump reservoir to the power steering pump.
2. Install the power steering pump pulley to the power steering pump.
3. Position the power steering pump to the engine.
Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts.
Tighten the bolts to 25 Nm (18 ft. lbs.).
5. Connect the power steering pressure hose to the power steering pump.
6. Connect the power steering return hose to the power steering pump.
7. Install the harness connector (1) to the power steering pump (4).
8. Install the accessory drive belt.
9. Fill the power steering system with fluid.
10. Bleed the power steering system.
11. Operate the power steering system and inspect for power steering system leaks.
No matter how easy it appears the hard thing to do is getting the bolts back in the holes by ones self
In
relation to these problem there are few solved help links,i suggest you to go
through the list and click the required link:-----
http://schematicsdiagram.blogspot.in/2012/04/power-steering-going-out.html
http://schematicsdiagram.blogspot.com/2011/12/steering-wheel-locked.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-power-steering-pressure.html
http://howtobyme.blogspot.com/2012/01/how-to-replace-power-steering-pump-on.html
http://repairhelpcenter.blogspot.in/2012/02/how-to-bleed-power-steering-pump-on.html
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-steering-pump-on.html
http://technoanswers.blogspot.in/2012/02/steering-service-light-on-gmc-sierra.html
http://technoanswers.blogspot.in/2012/02/on-one-my-pontiac-grand-prix-relatred.html
http://schematicsdiagram.blogspot.in/2012/02/check-power-steering-message-on-toyota.html
http://carbeltrouting.blogspot.com/2011/12/1992-ford-aerostar-power-steering-and.html
Also bleeding:
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-linkage-on.html
http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-pressure.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-wheel-on-acura.html
http://howtobyme.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
These details will help.
Thanks.
How to bleed power steering pump on Toyota?
----------How to replace power steering pump on Toyota Land cruiser?
Steering service light ON GMC Sierra Denali?
Steering service light came on 2004 Pontiac Grand Prix
Check power steering message on Toyota?
How to remove power steering pulley on 2002 Ford Taurus?
http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-steering-pulley-on.html
---------1992 Ford Aerostar Power steering and
Alternator belt routing diagram?
How to replace Power Steering Pump on Acura
Car Models?
Also bleeding:
How to replace Steering Linkage on Acura Car
Models?
How to replace power steering pressure hose on mustang?
STEERING SQUEAKS
http://alltypesofpartsreplacing.blogspot.com/2012/10/steering-squeaks.html
Steering
Column Diagram For 1990 Jeep Wrangler
http://schematicsdiagram.blogspot.in/2012/07/steering-column-diagram-for-1990-jeep.html
How to replace Steering Wheel on Acura Car
Models?
How to replace Power Steering Pump on 1999
Acura TL?
Thanks.
Replacing your power steering pump sounds like it could be difficult. My brother had to try to figure out how to fix his steering a few months ago. It seems like it would be best to let a professional handle a job like this. http://www.perthgearbox.com.au
