SOURCE: my galaxy tablet cannot detect
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
SOURCE: I have the Archos 101
I had the same problem with my third Archos 101 (I've had two replacements to the first one I bought in June 2011). I just got the third one two days ago and it wouldn't connect to my WiFi like the previous two would. I had to add the 101's MAC address to my router's setup and now I'm connecting to the Internet. Alternatively, if your cell phone supports tethering (my HTC Tilt does) you can tether your 101 to access the Internet through your phone. Mine is working well that way....for now.
You might have something going on in your settings. I remember the first time I tried to connect to a network. It was a nightmare. I was pulling my hair out! You only have one device to connect. I had three devices and none of them would connect until I went in and changed my settings. I hope this was helpful. Good luck.
SOURCE: wifi connection is slow
If the wifi network works fine with your laptop and not with your tablet, Then there must some problems with the tablet's antenna. Try for a replacement if it is new.
If the speed test gets hanged on your tablet, Try to test with any other source. For example, you can test the internet connection speed from www.scanmyspeed.com It does not require flash support too. So it has not much chances to get hanged.
When entering the password there is a tick box that allows you to save the settings and connect whenever this wifi available, check the settings from the password page!
Testimonial: "i dont see this tick box. when i enter the settings mode, locate my hub, key in the password, there are 2 tick boxes, one that says show password and one that says show advanced options. neither of these give me the option to save the password."
Hi kraig reichley, I want to help you with your question, but I need more information from you.
Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7/
