SOURCE: Casio 120cr-b cash register
Hi. If the printer spins at turn on, then gives the error, it will most likely need the printer repaired. This is a common problem with this printer. It has nothing to do with ink. If you want to replace the ink, you buy a new ink roller for it. NEVER re-ink the old roller or you will have trouble. Suggest you take it to a Casio agent to have the printer repaired.
SOURCE: cash register showing E94
Hi. It has a printer fault. Make sure there is nothing stuck in it. If the printer spins at turn on then it is probably an electrical problem and you need to take it to a dealer.
SOURCE: Cash Register Casio 240cr displaying error code E94
Your printer is jammed, mistimed, or broken
SOURCE: I have an old CASIO 120CR-B cash register, which
E94 is definitely a printer failure message, so if you can't find a paper jam, then the printer has a sensor problem or possibly a broken gear or changeover coil. In a budget machine like that one, the printer is usually replaced, but it costs half the price of the machine, so it may not be worthwhile.
If anyone needs a manual for a Casio 120CR or 160CR, there is one here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_120CR_and_160CR_users_manual.html
120CR-B and 160CR-B
http://the-checkout-tech.com/manuals/cashregisters/Casio_120CR-B_and_160CR-B_user_manual.html
Testimonial: "Thanks, definately a good help !"
