I clicked autohide and I can't find sidebar. How do I restore it on my desktop
Okay go to start and open the control panel. Click on the appearance and personalization link, Click on windows sidebar properties and select start sidebar when windows starts. Then log off then log back in, and you should have your sidebar again.
Hope this helps,
Ryan Frame
Creative Energy Associates Technical Center
Hi jeff,
left-click the start button, the right-click blue background of opening window, goto properties, disable auto-hide feature and enable side side-bar.
good luck
Go to control panel , there is option for Windows sidebar properties. Just click it and there is option for "Start sidebar when window start" Just check it.
gud luck
Click on "Close Gadget." The search function is now gone from the sidebar; however, the search gadget is still installed on your computer for future use if you ever decide to re-add the item to your sidebar.
To completely remove the sidebar search gadget from your entire computer, follow the next steps.
Right-click on the Windows sidebar.
Click on "Add Gadgets" to open a window containing all sidebar gadgets installed on your PC, including the search gadget.
Right-click on the sidebar search gadget you want to remove, and click to select "Uninstall."
Click "Uninstall" again when a Windows notification pops up, asking you to confirm the uninstall process.
After you click, the program will automatically be removed from your PC and it will no longer appear on the listing of available sidebar gadgets for Vista
windows 7
Click "Start."
Click "Control Panel."
Double-click "Windows Sidebar."
Remove the check from the box next to "Start Sidebar when Windows Starts."
Click "Save." Now, the next time you load your computer Windows Sidebar will not start.
hope this helps
