Refrigerators Logo
Posted on Sep 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE GTS20ICNCC Refrigerator light bulb burns out quickly
My GE GTS20ICNCC refrigerator light bulb consistently burns through light bulbs in about a month. How do get a light bulb to last in this refrigerator?
Adnan Bhatti
Level 3:
President:
  • Master 1,188 Answers
  • Posted on Sep 07, 2009
Adnan Bhatti
Master
Level 3:
President:
Answers
1188
Questions
Helped
410169
Points
3822
Use the correct wattage bulbs. If they fail often then you may need to get it checked by an electrician.
Filament bulbs easily burn out. What you can do is to buy cheap bulbs and replace as soon as they burn. This is the problem which is why tube lights and LEDs were invented!
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
1helpful
How to replace the upper light bulb on my ref
Here ya go, the manual. Most fridge light bulbs are easy and quick to swap out. If it's covered by a clear cover, just remove cover and unscrew bulb. General Electric Side By Side Refrigerator Specification Sheet...
How to change light bulb in ge refrigerator model gts18dbpalww
Unplug the refrigerator. For the refrigerator, unscrew the old bulb or bulbs and screw in a new appliance bulb of equal or lower wattage. For the freezer compartment, if a lamp is present, squeeze the top and bottom of the cover together then unscrew the bulb. Then screw in a new appliance bulb of the same wattage and replace the cover.
Note the appliance bulb is an incandescent bulb and may be hot.
The manual is available here: http://www.managemylife.com/mmh/owner_manuals/5791/GE-Top-Mount-Refrigerator-L0307014?brand_name_search=gts18dbpalww+ . The lamp replacement is given on page 13.
I hope this helps.
1helpful
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Chasnge light for water dispenser
Dispenser
The bulb is located on the dispenser
under the control panel.
Remove the light bulb by turning
it counterclockwise.
Replace the bulb with a bulb of the
same size and wattage.
Plug the refrigerator back in and you are ready to go!
Thanks, Sea Breeze
I need to know what bulbs I need fo rthe GE
main bulb is ge part # AP2006861 and is a 60 watt common light bulb/the dispenser bulb is a g.e. part # of AP3884244 and you should be able to get these at a grocery store or ace hardware
3helpful
2answers
The light bulb burned out. I do not know what type and and wattage of the bulb to replace it.It is the refrigerator light bulb in GE TFX24R refrigerator. Thank you my email is [email protected]
According to GE this uses a 40 Watt appliance bulb. You should be able to get one from any department or home improvement store.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to give the best FixYa experience.
6helpful
2answers
How to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Top Refrigerators Experts
vince
Johnny 1000
