When cleaning everything change the main filter which it's the filter inside the yellow mesh holder. the filter number is 1010fs. One filter is 26.90 with s&h. This needs changing every 2 years.
call customer service number above.
Fantom customer service 1 800 275 9251
1 800 798 7398
On my fantom cylone I use a 2 foot wire with small hook. Open bottom and push wire up the vacuum channels. There is also a channel that goes to the brush. Check for suction at hose. If none then your one of your channels going up are blocked. If you have suction at hose but none at floor brush then channel to floor brush is plugged.
I have the same problem, belt turns, checked for blockage and found none, unit just seems to not have any suction
