Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
Anonymous Posted on Sep 07, 2009
Date time stamp
I need the Date/Time stamp to be on, so it displays the date and time info on the photograph. In the settings, the option to turn the date stamp on is there but not accesable. How do I turn this setting on?
old marine
Level 3:
  • Master 2,426 Answers
  • Posted on Sep 08, 2009
old marine
Master
Level 3:
Answers
2426
Questions
0
Helped
951748
Points
10742
The camera must be set in the Postcard mode under the resolution setting (L, M1, M2, M3, S, Postcard) on the function menu. Press Function, scroll down to bottom, then scroll to the Postcard mode and press the Set button.
Testimonial: "Fantastic! I've been trying to sort this out for ages, and that has done the trick! Cheers :) "
  • al67rm Sep 11, 2011
    thank you old marine! Alex
Is it possible to stamp date and time on pictures using a kodak cd82 camera?
To set the date and time on your camera, follow these steps:
Turn on the camera and set the language and date/time by following the instructions in the Extended User Manual.
Once you have set the date and time, you can turn on the Date Stamp feature by following the instructions in the User Manual . The date and time will be stamped on all pictures taken with this feature enabled.
KODAK CD82 - EXTENDED GUIDE EXTENDED USER MANUAL Pdf Download ' ManualsLib
KODAK EASYSHARE CD82 USER MANUAL Pdf Download ' ManualsLib
1helpful
How do I turn off the date and time stamp on the camera so it does not show up on the printed pictures?
There is a setting for that on your camera.. Hard thing is finding it with all of the material that is in there.
Sep 17, 2017 • Cameras
1helpful
How do you set the cannn 500d to date stamp pictures that you view
If you want to see the date /time info while viewing the pictures on the camera, you can change the display settings, press the DISP button, till you see a smaller picture and the date and time on the bottom of the screen.
If you want the date and time printed on a picture, you should use the pict bridge option from the camera and in the setup you should chose the setting for that. See page 165 and following from the manual.
But the simple timestamps of the yellow or orange stamps like in the older digital cameras, won't work.
Because the camera keeps a all information stored in the EXEF part of the picture, it won't destroy the jpeg it produces. If you really want the date and time imprinted, you should use a program on the computer, to use the date and or time info and brand it in the picture, before saving it.
Be aware all pictures do have the date and time info in them and most viewers on the computer (whatever OS) will show the info when asked, anyway.
Sep 08, 2014 • Cameras
1helpful
3answers
How do i remove the time and date at bottom right corner of picture.
Manual can be downloaded free from here ....
http://safemanuals.com/annexe_POWERSHOT%2020A550%2020CAMERA%2020USER%2020GUIDE%2020ADVANCED%2020_CANON_POWERSHOT%20A550-_E.htm
Basically the date stamp can be turned on / off as an option on the RECORD menu. Page 33 of the manual explains it (with pictures).
Note that if the option is turned on, it states that the date / time is permanently embedded in the picture.
Hope this helps
3helpful
2answers
Displaying time and date when printing
The date/time cannot be deleted once it is embedded in the image. To turn off the date/time deselect the date/time stamping by following procedure:
These instructions explain how to insert the date in images.
attention:
  • The [Date Stamp] cannot be deleted from the image data once it has been recorded because the date is written in as an image.
  • When selecting [Date Stamp] , [Recording Pixels] is set to 1600 x 1200 pixels and the compression (image quality) to [Fine].
  • When the shooting mode is set to <Movie> (g0029623.gif), settings for inserting the date and time cannot be made.
  • The following explanations are provided based on the assumption that the [Shooting Mode] is set to <Program AE> (g0034813.gif).
1. Press the <Power> button on the camera.
2. Press the <FUNC./SET> (g0046915.gif) button.
3. A screen like the one below will appear on the monitor.
Select g0013174.gif [Date Stamp] (g0013171.gif) in the [Recording Pixels] section g0013173.gif.
g0013176.gif Press the <MENU> (g0046624.gif) button.
4. A screen like the one below will appear on the monitor.
g0013173.gif Operate the <directional buttons> left or right to select [Date Stamp] and set it to [Date] or [Date & Time].
g0013174.gif Press the <MENU> (g0046624.gif) button.
5. Press the <FUNC./SET> (g0046915.gif) button.
6. Make sure that the [Date Stamp] is set and the following screen will appear with the icon (g0013164.gif) in the lower-left corner of the screen.
7. When shooting with this setting, the date will be embedded in the image as shown below.
g0013173.gif [Date]
g0013174.gif [Date & Time]
warning: The date, its font and color, and the position where it is displayed cannot be changed. Also, dates and times recorded with [Date Stamp] cannot be deleted.
If you need a manual for the A480, you can download it from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=18155
Please rate this solution. Thanks.
8helpful
Cannot turn date stamp on in menu settings.
Date stamp is only possible when you set the resolution (picture size) at "Postcard 1600x1200" option, if the date stamp is set to "Date & Time" or "Date" option
16helpful
Date display in photos in IXUS40
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
your date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
[email protected]
1helpful
Time and date display
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or View picture you want date & time stamped. Press the circular 'Menu/Set' button Press down arrow to playback mode Press right arrow on 'text stamp' Choose whether to apply stamp to single or multiple photos Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
2helpful
2answers
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Push the function/set button. Press the directional button down to select Date and Time.
Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Show the Date stamp on the picture
One reason why the date stamp is not showing would be that you have not set the system date/time. The date/time resets everytime you take out the battery. Please go to this link and download the userguide... http://alpha02u.c-wss.com/inc/ApplServlet?SV=WWUCA900 file name : PSS500IXUS500CUG-EN.pdf ...Go to page 26 which will tell you how to set the date/time and then go to page 109,113 for the date/time to be displayed on the photographs. Please tell me if this helps
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
