Question about Sony Televison & Video
Sony remote rm-sx800 stopped working
Inserted new batteries, remote worked at that time. After playing one disc renote was no longer working.
SOURCE:
SOURCE: Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Posted on Dec 26, 2008
  • 67 Answers
SOURCE: LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Posted on Jan 20, 2009
SOURCE: Code for Sony RM-V310A remote.
How do I program sony universal remote RM-V310A for a polaroid flat screen TV
Posted on Sep 09, 2009
SOURCE: Sony remote RM-DX500 not working with Disc
There are 2 set's of command switch's for the dvd player, a 3 position command switch on the back side of the dvd player and another 3 position command switch on the inside of the remote right next to the batteries, easiest option is to remove batteries from remote and test each one of the 3 position switch's labeled 1,2 & 3 and test remote control.
Posted on Dec 24, 2010
  • 24 Answers
SOURCE: My RM-YD028 Sony BRAVIA Remote
Remove the batteries from the remote and wait 5 minutes or more. After waiting, insert the batteries again. The remote should now work. If it's still not working, the remote is probably defective. If that is the case, please contact Sony Customer Support, which will be able to assist you in getting a replacement issued.
Posted on Jun 01, 2011
How to unlock my sony bdps300 blue ray player
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
  • While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
  • After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control.
NOTES:If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode.
Each time this procedure is performed the disc tray will either lock or unlock.
Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you.
Thanks for understanding.
Jan 19, 2011 | Sony BDP-S300 Blu-Ray Disc Player
My sony dvd player will not allow the tray to eject. when the eject button is presses "tray locked" appears on the screen
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control. NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode. Each time this procedure is performed the disc tray will either lock or unlock.
Jan 02, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Need code number for Sony RM EZ2 for Direct TV box
There are codes available at this site:
http://2getdtv.com/directv/directv_receiver_codes.html
Hope this helps.
May 07, 2009 | Sony RM-EZ2 Remote Control
Sony RM-VL1000 stopped working
Dump the Sony "Integrated Remote Commander RM-VL1000" and go to WalMart (or wherever) and purchase any other brand and model for under $15.00.
You'll be so much better off!
Mar 21, 2009 | Sony RM-VL1000 LCD Remote Control
Remote model [AV SYSTEM 3] RM-SS880 not working :
Need remote code for this home theater. I have Sony RM-V210T universal remote but cannot set it up to work with dav s880. Only PLAY button is working...
Mar 19, 2009 | Sony (RM-SS880) Remote Control
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Lost Instruction Manual Paper for Sony RM-V401 Remote Control
You must press "set" button (with a pen), then press "tv" followed by the code you have and finally "enter". Regards
Jul 13, 2008 | Sony RM-V401 Remote Control
Menu reads "Disc is dirty" and refuses to play disc when inserted
One note my friend don't buy SONY they have propriety tech on they're lenses that has poor Pickup on some CD\DVD's.
Sep 21, 2007 | Sony DVP-NS55PS DVD Player
Televison & Video Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
