Question about Garden
Do you know where I can purchase the saw drive assembly for a Model JDF-4ET 18 20V Pruning Saw
3 Suggested Answers
SOURCE:
dontbother10
  • 2220 Answers
SOURCE: bond pole pruning saw assembly
Please close this - per customer request.
Posted on Sep 21, 2009
  • 2239 Answers
SOURCE: What is the oil/fuel ration
With Husqvarna two stroke oil it should be 50-1, with other manufacturers two stroke oil it is 25-1 as we do not know the quaility of other oils, always try to use Husqvarna oil.
Posted on Jul 29, 2011
How can I use a gas pole saw?
Congratulations on getting you a new gas pole saw! A gas pole saw is undoubtedly the most powerful of pole saw types. It uses gas for operation, heavy-duty bars, and chains and is effective for a longer working period. Since it is the most powerful; you can put your faith for pruning heavier and larger branches and trees.
So, you have chosen rightly. But, it is a matter of concern, if you do not know how to use a gas pole saw. Let us help you with this matter.
BEFORE YOU START
  • Make sure that the pole saw is safe and prepared to be used. The faulty ones can lead to a serious accident.
  • Clear the area where you would use your pole saw and where the limbs would fall. Any hazard should be cleared at once.
  • Be aware of the weather because the windy or rainy weather can turn your pruning into a dreadful experience.
  • Cut only one limb at a time
  • Avoid cutting branches that are thicker than 8 inches. Take expert's help in this matter.
  • Be aware of the kickbacks.
  • Always maintain the right balance and base. Hold the saw firmly and stay at your place rigidly.
These instructions should be taken into account before the start of trimming. After you follow the instructions given above, it is time to move towards pruning process. The steps below lay out how to use a gas pole saw.
STEP 1 As you hold the grip of your pole saw and make a balance of your position, make few jump cuts underneath the branch you want to cut off. Jump cuts are a necessary technique which is used before the final cut. It reduces the weight of the branch that makes the final cut easier. It can be physically challenging to cut from underneath. So, always pick a pole saw equivalent to your weight bearing capability.
STEP 2 Extend the height of the pole saw based on the height of the branch. Hold the pole saw vertically, take it up to the branches away from the ground and never forget to hold it properly. Adjust its position and let it rest on the branches. In the meantime, you can ensure your position too. Always keep the pole saw at your chest level.
STEP 3 Now, begin to cut perpendicular to the limb and try to make deep cuts as much as you can. Deep cuts will let you make the final cut and other cuts easier. It will also allow you to make faster cutting strokes. Readjust your position, and the pole saw if you face any trouble.
STEP 4 The last step is all about your safety. Check where the limbs are falling and move from that place as early as possible.
Do not lose hope if you fail the first time. Keep trying until you reach your full potential. Clean the work area after trimming is done. So, this is how you can use a gas pole saw. Keep pruning and stay safe!
More details open the link Guide on How to Use Gas Pole Saw
Apr 11, 2018 | Garden
Where can I purchase a replacement battery & charger for a tornado cordless pole saw
Try searching for a battery pack rebuilder in your area.
They will look at the current cells in your battery pack and try to find suitable replacements of the same size and amperage
Nov 10, 2017 | Televison & Video
Do you have a better pruner?
Ryobi P4360/P4361 Cordless 18v ONE+ System Pole Saw ...
? 13:42
www.youtube.com/watch?v=PFANQ0JgpZk
Jun 12, 2013 - Uploaded by 8digitPDX The Ryobi 18v Power pruning saw - surprisingly good performance for the money from a ... Ryobi P4360/P4361 Cordless 18v ONE+ System Pole Saw Tree Pruning Saw .... Lithium-ionPole Saw - Unboxing and Review!
Oct 08, 2015 | Garden
Lost maintainance instructions for NNP 2018 pole pruning saw Chain jammed some teeth are out of line
It sounds as though you have bent drive links? I would probably replace the chain. Burrs we can help, see Chain Repair here:
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
The instruction sheet is available here:
Black & Decker
Go To “ServiceNet/” link
Bottom of center column “Need a Manual?” Enter model number, “YourModel” in window.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 02, 2010 | Black & Decker NPP2018 18 Volt Cordless...
Battery fully charged but pole prunning saw does not work at all poles are connected properly
You do not mention the model number.
Honestly, I had never used a pole saw, but I needed to cut down a lot of tree branches and Black+Decke worked wonderfully. With it being cordless I could easily walk around my entire yard without worrying about it. The chain does loosen after cutting through several limbs, but it's super easy to tighten back. It's easy to assemble.
More details Practical Black and Decker Pole Saw Review
Jul 24, 2009 | Black & Decker 18 - Volt Pole Pruning Saw
Ryobi pole saw model ry52502
my Ryobi RY52502 starts but when i change the lever from start to run, it will shut off
Feb 03, 2009 | Remington 111409 - 01 6" Branch Wizard...
Garden Logo
19 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
