SOURCE: Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
SOURCE: Hi I have a Winner
I have a parts breakdown for this unit in a PDF but they made about 3 different styles of hoses and trigger guns, if you send me a email at [email protected] I can send you the breakdown and you tell me what one you need.
SOURCE: HI Have a Sony HCD H51 CD spin motor not turning
check the ic and the transistor that the motor feeds from they might be bad.good luck.
SOURCE: Where can I get an online Instruction Maunual for the Karcher Winner 11
http://www.rjbowers.com/machine_list.php Click on blue search list box - type winner in box - hit enter key and the parts list and manual will come up. Or call RJBowers tomorrow and we will email the manual. 800-383-6584
SOURCE: how to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
Testimonial: "Thank you thats most likely the problem. no just to get it fixed. "
