SOURCE: My hose connection is leaking water
Jonathan, first unscrew the hose connection. Now look into the end of the hose for a rubber seal. The color of the seal may be black or green or red or yellow or some other color. Does this seal exist at all? I once had purchased a hose and found out the seal had fallen out sometime before I got it home. If the seal is there, remove it and get another seal. They are inexpensive, but usually must be purchased in quantities of 10 or more.
SOURCE: Whirlpool Dishwasher DU850DWGX1 won't completely drain
Commonly this is result of low water pressure or hose height/length
As long as the water is below the heating element and the dishes are getting clean its actually normal. Sometimes the pressure or hose length/height meets specs but will not always drain all water.
But as long as it is below the heating element this is normal
I am sure.
SOURCE: washer drain back flow to sink
No you do not want to restrict the machines pump out feature, FIX the house drain! call Roto Rooter if necessary.
SOURCE: Water overflowing from drain pipe
The problem with the new washing machines, is that they dump 20-22 gallons of water in 4-5 seconds. This amount is far more than the garden hose test will submit the drain to. Here are a number of solutions, I hope that one of these will help you.
#1 As mentioned above, you can restrict the flow of the drain pipe. I recommend a 3/4" x 6" brass nipple, or a 1/2" x 6" brass nipple, depending on your specific situation. The brass nipple will not corrode like a galvanized nipple.
#2 There is also a rubber cap that you attach to the drain pipe that fits around the drain hose tightly.
#3 Some situations might require that you have to raise your drain pipe. It is recommended that it be at least 36". This allows for gravity to assist the drain.
#4 Some situations will require that the drain pipe be increase in diameter. Older plumbing applications were installed using 1 1/2" piping. With the newer washing machine discharge volume, the 1 1/2" pipes will not support the discharge. Your drain line will need to be changed to 2". This option will be one of the more costly fixes, depending on the amount of line that needs to be changed.
#5 Some plumbing installations installed without a p-trap will need to be changed. The p-trap keeps sewer gas from coming back into the house. It also allows for a smooth transition into the drain line. Any restrictions in the drain line (i.e. ells, tees,) will cause the soap in the gray water to foam up which will cause the drain line to slowly back up.
I hope these solutinons help.
