Question about Kenmore Washing Machines
Kenmore he 2plus front loader washer error code 28
SOURCE:
  • 51 Answers
SOURCE: Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
Posted on Mar 13, 2009
jsrock516
  • 5911 Answers
SOURCE: How do I stop my Kenmore front loader from leaking
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Posted on Jan 31, 2010
  • 662 Answers
SOURCE: F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
Posted on May 19, 2010
TheMobilian
  • 8220 Answers
SOURCE: F 28 error code Kenmore front load washer
F28 Com error between MCU and CCU (central control unit) Broken wire. Check the harness closely between central control and motor control unit. Remove the bottom panel and fish out the tech sheet. Duet manual and more photos HERE0e21d99.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 05, 2010
Macmarkus
  • 2605 Answers
SOURCE: Just received error code 5D
Hello, welcome to fixya.
Based on your post I understand you have a "SD" error problem (looks like a 5D in the digital display) with a Kenmore washer, the error means an excessive drain time or excessive suds was detected as you may or may not already know.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is)
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony.
Regards,
Macmarkus :)
Posted on Jun 26, 2011
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
Jul 22, 2013 | Kenmore Elite 45986 Front Load Washer
Just received error code 5D Kenmore HE 2Plus Front Loading Automatic Washer
Regards,
Macmarkus :)
Jun 26, 2011 | Kenmore HE2 Plus Front Load Washer
I have a 5d fault code on my HE 2plus kenmore washer.
  1. Remove the lower front panel and remove the cover for the drainage filter. Slide this tray out and clean it.
  2. Unplug the washer for at least 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit.
  3. If the above procedures do not correct the problem, it is recommended to replace the drain pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Kenmore HE2 Plus Front Load Washer
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
Jan 31, 2010 | Kenmore HE2 Plus Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Error code F-28
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Washing Machines Logo
26 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
