Hi my Yamaha rx v690 right output speaker cuts in and out when I'm play my Xbox one via toslink and toslink to rca converter Currently thru the tv. How can I fix it?
Hello Michael, for what you comment, you have connected the X-Box to the Yamaha through a Digital-A converter
First try another sound source, example FM, if you also chop the right channel, the problem is in the audio output of the Yamaha
If FM is heard properly, then try replacing the RCA RCA cable between the Digital-A converter, if it still continues, change the input on the Yamaha and if it still follows the fault, replace the D-A converter
I hope you can solve your concern
Greetings Franco Dosil
Hola Michael, por lo que comentas, tu tienes conectado el X-Box al Yamaha a trav?s de un conversor D-A
Primero prueba otra fuente de sonido, ejemplo FM, si tambi?n se entrecorta el canal derecho, el problema esta en la salida de audio del Yamaha
Si se escucha bien FM, entonces prueba reemplazar el cable RCA RCA entre el conversor D-A, si aun continua, cambia la entrada en el Yamaha y si aun sigue la falla, reemplaza el conversor D-A
Espero puedas resolver tu inquietud
Saludos Franco Dosil
https://www.hifiengine.com/manual_library/yamaha/rx-v690.shtml
https://de.yamaha.com/files/download/other_assets/4/334534/RX-V690.pdf
SOURCE: Setting up a Yamaha RX-V690 home theater system
you almost have the exact same situation i am in. i have the same receiver, and going to purchase a panasonic 50" (th50px75u). i think what i will be doing is running a hdmi from my hd cable box to my tv, and installing an audio cable (red/white) from my tv to the receiver. i believe there is an audio input below the hdmi insert. i have polk audio, but theyare about 10 years old, they sound great, but just too large....and may be purchasing a harman kardon system. which models do you have from polk? i have the rt16's, cs350ls center, and fx/500 rears. let me know what you have come up with as well...as it has been a while since you posted this.
cheers,
sean
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
SOURCE: Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
SOURCE: Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
i have no sound when trying to watch a dvd through my rxv2700. the dvd player is an insigna blue rya player. It worked at first but not now
SOURCE: My Yamaha receiver model rx-v565 audio is putting
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
