Xerox 212 Laser Printer Logo
Posted on Sep 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Copier is a 214 and shows U6 code
The copier was working fine, however, now it shows a U4 code and will not do anything. Your help would be greatly appreciated !
Gilbert Gonzalez
Level 2:
  • Expert 239 Answers
  • Posted on Oct 17, 2009
Gilbert Gonzalez
Expert
Level 2:
Answers
239
Questions
Helped
104973
Points
365
A U-6 means the memory on the main board failed.
If the machine is old, the battery on the board is old and not holding the values in the machine.
Replace the main board will correct the problem.
Since it is in the middle deep in the machine you might need to have Xerox repair it for you if they still provide service to this model.
Good luck.
3helpful
2answers
Copier is a 214 and shows U4 code
turn on power while holding down "0", press "stop/clear" and wait 30 seconds for optics to finish initializing, then enter "401" then "print", shut off machine, wait 10 seconds and turn back on. code should now be cleared.
2answers
Sharp Ar-5132 U6 code after moved the copier
U6 code indidcates a laser problem. It may have been shaken or bumped a little too much in the move.
2helpful
4answers
I have a Sharp SF-2022 copier and it flashes a U6 code abd will not work. How do I fix this?
u6 is sually something to do with the papaer tray or feed section check to make sure the tray is set properly and that you have the guide plates set correctly and that the tray is fully set
2answers
I Have Xerox 5821 Star Copier and it got U6 error. Help me out
U6 code means that you have a problem with the exposure lamp or exposure lamp circuit working properly.Hold down the 0(zero) key while turning the unit on and punch in the codes 20 start 3 this will enable you to clear the code unless you have a permanent problem where a part has to be replaced
4helpful
2answers
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
3helpful
My machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
My xeros 214 copier has gone wrong and the no U4 is coming up, i do not have a manuel thanks terry
A U4 is a fuser overtemperature.
You can hold down the "0" while powering the machine on. That will enter the machine into diagnnostics.
Next enter code 401, and press start, See of that clears the problem.
If it does. Remove the fuser and clean the buildup off the thermistor.
If it doesnt you will most likely have to replace the fuser.
Xerox Copier 214
If it does. Remove the fiser and clean the buildup off the thermistor.
8helpful
4answers
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
