IF YOU WOULD PUT YOUR QUESTION IN THE CORRECT HEADING IE: CALCULATORS OR WHATEVER, YOU WOULD GET A CORRECT RESPONSE!!!!IF YOU WOULD PUT YOUR QUESTION IN THE CORRECT HEADING IE: CALCULATORS OR WHATEVER, YOU WOULD GET A CORRECT RESPONSE!!!!
You can't post conmments that contain an email address.
Below are the steps to assist you in setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are on the faceplate above the respective key. Position the calculator so that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press the AM/PM accordingly.
4. Firmly press and release the TIME SET key. The first digit should stop blinking and the time is then set. The seconds will again be displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To return to either the TIME or DATE, press the CALENDAR/CLOCK key to toggle between them.
Setting the date:
Setting the time:
Setting the date:
Setting the time:
Setting the date:
Setting the time:
Setting the date:
Setting the time:
Setting the date:
Setting the time:
Setting the date:
Setting the time:
Setting the date:
Setting the time:
How to set the ULTRONIC WORLD TIME CALENDAR 01-22-2011 1. press the SET (MRC) key. The SECONDS in the lower right corner will start to blink 2. press again and the HOUR will start to blink. And again for the MINUTES, again for the YEAR, again for the MONTH, and again for the DAY DATE. 3. when you get the number you want to set, press the UP (M-) or DOWN (M+) ARROW key to adjust that number as you wish. 4. then press TIME to lock in that number. 5. repeat as needed to set the other numbers
