SOURCE: Dishwasher - Kenmore 461 14352 - E2 error?
With registration, you can probably get a download of your manual (user guide) here:
http://www.managemyhome.com/mmh/
It may not contain the info you need since appliance service people hate do-it-yourselfers and, in my mind, manufacturers collude with them.
Can you believe that many TVs, radios, PC monitors etc. once came with complete circuit diagrams?
SOURCE: E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
SOURCE: error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
SOURCE: how do i fix an e2 error and get a wiring diagram
you can get new brushes here
http://www.partsfortreadmill.com/parts-for-treadmill/treadmill-motor-replacement/treadmill-motor-brushes-20x9x22-h-mm.html
and you can check here for treadmill help in general
http://www.treadmillsrepair.co.uk/
http://www.partsfortreadmill.com/repair/repair.htm
Hey friend, thank you for your inquiry!
The "E2" error code means that thermistor/turbidity sensor has failed. This can be corrected by replacing the turbidity sensor or main control board. I would suggest contacting a professional to come and properly diagnose your appliance to avoid any unnecessary part purchases. -Matt
