The unlock scanner message appears. What am I supposed to do?
Thanks.
See
http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Have you tried the chat with support link on the right side of this page mid way down?
http://support.dell.com/support/topics/g...
Thanks pashs19. Your explanation was very clear. I have done this previously and it does nothing to clear the message to unlock the scanner.
Said unlock scanner and the turn on power. Where do I unlock it?
Error message Unlock Scanner then Press Power.
I lifted the lid pushed the unlock lever left of the green support. turned power back on. repeated about 100 times. Unplugged the printer. Unistalled and reinstalled the software and tryed the scanner lock lever about 10 more times. Is there a solution or is it a design flaw and time to buy another?
will not print color
when i try to scan a document on my dell 946.It comes up with applications not found.How do i fix this
When I try to scan an image using my visioneer one touch 9000 scanner a message keeps appearing telling me that the scanner is locked. The switch at the bottom is in the unlock position & I have re-installed the software but message keeps appearing.
it is asking me to unlock scanner, and i dont know how to do that.
need help with error code "Unlock Scanner". It is unlocked. The error code will not go away
