Jet 3 Ultra Power Chair Logo
Anonymous Posted on Sep 06, 2009
Pride mobility Jet 3 Ultra Power Chair 7 flashing lights. joystick error. how do i fix ? Three red LEDs Four yellow LEDs
Anonymous
Level 1:
  • Contributor 29 Answers
  • Posted on Sep 07, 2009
Anonymous
Contributor
Level 1:
Answers
29
Questions
0
Helped
17103
Points
57
A 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Jet7 power chair flashing red and yellow lights and not staying charged but a few hours at a time, had battery check, said they were ok. help
Hi June,
Any electromechanical device requires occasional troubleshooting. However, most problems that arise can usually be solved with a bit of thought and common sense. Many of these problems occur because the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge. Below are a series of basic troubleshooting instructions for the Jet 7 Power Chair. This information is to be used as a supplement to the troubleshooting instructions provided in the owner's manual. If you have any questions about this information, contact your authorized Pride Provider. What if the systems on my Jet 7 seem to be "dead" (controller does not light up when the on/off key is pressed)? ! Make sure the batteries are wired properly-refer to the battery wiring diagram located on the power base. ! Make sure the connections on the battery terminals are tight and secure. ! Make sure the battery quick-disconnect harness connections are fully joined. ! Make sure the main circuit breaker has not tripped-push in the main circuit breaker reset button. ! Make sure the controller is completely connected to the power base. What if the range per charge of my Jet 7 diminishes over time? ! Determine if the batteries have ever been replaced. Batteries over a year old may be defective. ! Determine how frequently you charge the batteries in comparison to how often you use the power chair. If you use your power chair on a daily basis, you should charge the batteries every day for 8-14 hours. ! Determine when the batteries were last charged. Even if the power chair has not been in use, the batteries should be charged once a week for 12-14 hours. ! Determine how long you let the batteries charge. It takes 8-14 hours to fully charge a depleted set of batteries; continual undercharging reduces the overall life of the batteries. ! Observe the ammeter during battery charging to determine if the batteries are receiving a charge. If the ammeter does not go up when the battery charger is plugged into the charger power cord receptacle and an electrical outlet, the batteries are not getting charged. Check the charger fuse and ensure the electrical outlet is good. ! Determine if a wall switch controls the electrical outlet used for battery charging. If a wall switch does control the outlet and the switch is turned off inadvertently, the batteries will not fully charge. ! Is an extension cord being used to connect the battery charger to the electrical outlet? Pride prohibits the use of an extension cord when charging the batteries. The charger should be plugged directly into a properlywired standard electrical outlet as the length and condition of the extension cord can have an adverse affect on the battery charger. ! Determine how far you let the battery condition meter LEDs go down before charging the batteries. If you continually allow the battery condition meter LEDs to fall into the red area, the overall life of the batteries will be reduced. What if my Jet 7 is operating slower than it has in the past? ! Determine when the batteries were last charged. When the battery charge gets low, the batteries supply less power to the motors, which causes the motors to spin slower. ! Determine the temperature of the power chair at the time the problem occurred. The Jet 7 electrical system will protect itself from overheating when its internal temperature gets too high by reducing the amount of power sent to the motors. When this happens, the power chair will gradually slow to a stop. Allow the power chair to cool down and it will resume normal operation.
What if my Jet 7 begins pulling to one side? ! Determine if the joystick is being deflected straight or at a slight angle. Even a small amount of deflection right or left will cause the chair to veer over a long distance. ! Determine if both manual freewheel levers are in the drive position. If only one manual freewheel lever is in the drive position, the other motor will not operate and the Jet 7 will veer severely. ! Determine if both tires are inflated to the proper psi if the power chair is equipped with pneumatic tires. Pneumatic tires should be inflated to 35 psi (2.4 bar). If one tire is inflated more than the other, the power chair will pull to the side that is underinflated. ! Determine if the caster wheels are pivoting freely. If either caster wheel is not pivoting freely, the unit will veer to the side. What if the Jet 7 powers up, but will not move? ! Determine if both manual freewheel levers are in the freewheel position. If the power chair is in freewheel mode, then the electronics will function but the motors will not spin the wheels. ! Determine if the controller is flashing a fault code. The Jet 7 comes equipped with a VSI controller. The VSI controller will flash a code via the battery condition meter LEDs if a system fault is detected.
# OF LEDS CODE CAUSE POSSIBLE SOLUTION One red LED 1 Low battery voltage Charge batteries Two red LEDs 2 Left motor open Make sure left motor is plugged into controller. Three red LEDs 3 Left motor wiring fault Contact your authorized Pride Provider. Three red LEDs 4 Right motor open Make sure right motor is plugged into controller. One yellow LED Three red LEDs 5 Right motor wiring fault Contact your authorized Pride Provider. Two yellow LEDs Three red LEDs 6 Inhibit active Contact your authorized Pride Provider. Three yellow LEDs Three red LEDs 7 Joystick error Contact your authorized Pride Provider. Four yellow LEDs Three red LEDs 8 Controller error Contact your authorized Pride Provider. Four yellow LEDs One green LED Three red LEDs 9 Brake fault Make sure both motors are plugged into controller. Four yellow LEDs Two green LEDs Three red LEDs 10 High battery voltage Contact your authorized Pride Provider.
What if the speed LEDs on the VSI begin to flash? ! Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, an internal charger inhibit feature keeps the power chair from driving. This is indicated by the VSI speed LED(s) flashing. ! Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to activate. ! Determine if all controller connections are plugged into the power base properly. If the 3-pin charger inhibit connector is not plugged in properly, then the charger inhibit feature will activate. What if the speed LEDs on the VSI begin to scroll? ! Determine if the VSI has been placed in lock mode. The VSI is equipped with a lock mode feature that prevents unintended use of the power chair. If the VSI is in lock mode, deflect the joystick full forward until it beeps, and then deflect the joystick full rearward until it beeps. The joystick should go back to the drive function.
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Three red LEDs
Three red LEDs One yellow LED
Right motor open
Three red LEDs Two yellow LEDs
5
Three red LEDs Three yellow LEDs
6
Inhibit active
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Three red LEDs Four yellow LEDs Three green LEDs
10
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
Pride Jazzy 1103 Ultra controller code: when the "on" button is pushed and held down, three red, four amber, and one green LED come on and are solid (not flashing), and there is a second LED gauge...
Seven blinking LED's indicate a "Joystick Fault" on the controllers Pride uses. Could be just the actual joystick itself, the part you move to make the chair move, or it could be other electronics in the controller. Here's a link to troubleshooting info:
Pride Mobility Products Corp Basic Troubleshooting Instructions
Joystick error code 7 flashing lights, 3green 3orange 1red
Check and see if the charger is still plugged in when you have this fault. Usually a 7 light flash is a controller fault. Sometimes it will also mean you have one or both motors disengaged. If the charger is not plugged in when you have this fault then try and push the chair. If it moves freely then you need to engage the motors. If you have to engage the motors you will have to power down the chair and power it back up to clear the fault. If this does not work you will need to contact a technician to troubleshoot the root cause.
1helpful
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
2helpful
When switched on power light flashes.
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Someone gave us a Jet 7 Power chair and we've replaced the batteries and the fuse. I've checked all connections and everything seems ok. but I'm missing something because I'm still getting 2 flashing red...
Assuming it is a P&G controller (it'll say PG Drives technology on the bottom of the joystick), two flashing lights is a left motor disconnect fault. Check the wiring from and to the left motor for tight connections at all junctions. Unplug and replug them, don't just wiggle test them. This should clear the fault.
9helpful
3answers
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
