SOURCE: I need to detach finisher from main body and then reattach once I have moved it to the next room.
Turn off main switch. Unplug power cord. Remove two screws where the extendable frame of the finisher connects to the copier. Unplug the connector cord from the back of the copier by pushing release button on the connector.. Done.
SOURCE: detach RICOH SR790 Finisher
Hello sir; Open the finisher door on the mid of right hand side ther have a cross bar fasten by one screw, loose the screw pull out the cross bar, it will detach from the machine.
Testimonial: "Thank you very much for your assistance. Simple when you know how ! WOuld be nice if Ricoh supplied this type of information direct to people."
SOURCE: how to install toner in kyocera TASKalpha 180
Open the front cover by grasping the detent on the left side.
Turn the blue knob up.
Pull out old cart.
Install new cart
Turn knob down.
SOURCE: I detached the finisher from the Canon ir5000
Check if the finiser is inserted properly, try few times.Be carefull with finisher hinges.
